Question about Vivitar ViviCam 5385 Digital Camera
Downloading pictures to my computer
When I plug the USB into my computer is says that there has been a malfunction and Windows does not recognize the camera.
  • Marcia Chumas Aug 02, 2007
    I took the camera to be fixed. It would cost about $200 to fix the USB connection. This for a camera that only costs about $100. I solved this problem by buying a $20 USB downloader. Thanks for trying to help.
My Usb stop working and how much will it cost 2 fix it
Posted on May 08, 2008
  • 641 Answers
Go to Vivitar web side and download to your computer the relevant drivers for your camera and OS. It should solve your problem. Good luck!
Posted on Jul 30, 2007
SOURCE:
Every time i plug in my camera to my computer, something pops up and says USB Device not recognized, it also says one of the USB devices attatched to this computer has malfunctioned and windows does not...
Try NOT connecting yoru camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jun 30, 2011 | Nikon COOLPIX L100 Digital Camera
When i plug Numark DJ/iO Sound Card in pop up message says "USB Device Not Recognized - One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it. For...
there are drivers needed for this item you may need to download them also re install your usb drivers an attach to a different usb port not thru a hub.
Mar 15, 2011 | Numark DJ/iO Sound Card
My computer does not recognize my cable from camera. It says the usb device has malfunctioned and windows does not recognize it.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 06, 2010 | Samsung Digimax D53 Digital Camera
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i connect the camera through the usb a box yellow appears from the corner (im using xp)..and the it says USB NOT RECOGNIZED One of the usb devices attached to this computer has malfunctioned and...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Plug my camera into the usb port, computer doesnt recognize it
Dec 25, 2009 | Samsung S860 Digital Camera
USB DEVICE NOT RECOGNIZED KODAK EASYSHARE C913 When I plug my kodak easyshare camera into my xp computer via a usb cord, i get the following error: One of the usb devices attached to this computer has...
remove you memory card
turn camera ON > Press Menu > go to setup menu> format internal memory>
take 1-2 picture > reconnect your camera to the computer>
if the camera will be recognized> reinsert the MMC> format the MMC > it will delete all your pictures including the corrupted ones
most of the time its just a MMC issue
good luck
Oct 16, 2009 | Kodak EasyShare C913 Digital Camera
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 23, 2009 | Canon PowerShot G10 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
112 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
