Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Can't get kodak to help with printer under warranty
I have been trying since Jan 4 to get a replacement power cord/AC adapter,first call they said they would send me a new cord(never received) but calls since then they say, we will call you back.They never do call back,how do you get someone at Kodak to help?TIA,Maggie
  • 837 Answers
Don't know what to tell you on how a company is performing when it comes to THEIR customer support .. but the best I can do is show you a place where you could just buy a new one on your own
Here is some on ebay
Posted on Jan 31, 2009
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
Not charging
1.Check the power outlet if it's working.
2.Try to also change the power cord with good one. If it works then the problem is the power cord.
3.Try to use a good know ac adapter to check if the only problem is the ac adapter. If it works then the problem is the ac adapter. If your still in warranty, you can go to this website to get a replacement ac adapter acclaim.toshiba.com or go to toshibadirect.com to order replacement for non-warranty.
4.If could borrow a battery that has same specs and size of your battery , you may put that on your laptop and try if the laptop will power ON. If the laptop won't turn ON, meaning there is a system board problem, if it turns ON the only problem is the ac adapter.
If your still under warranty, you may contact Toshiba, you may send it at no cost.
Mar 16, 2011 | Toshiba Computers & Internet
My laptop comes on but immediately turns back off after a few seconds. What's wrong
Sounds like a build up of static electricity. Try doing a power discharge.
1: Take out the battery.
2: From the adapter box (not the wall) unplug the power cord.
3: Press the power button 10 times. On the eleventh time hold it down between 25-35 seconds.
4: Plug in batter and power cord.
The computer should turn on. If not, the most likely cause is the system board or the AC adapter. You might want to try another AC adapter to ensure that the adapter is not the issue. If it's not the AC adapter then the system board is most likely dead and you need to call Lenovo (800-426-7378) to see if you're under warranty and can get the computer fixed.
Nov 06, 2009 | Computers & Internet
When i plug in the power cord in the back of the peinter the green light turns off. the printer will not turn on
It is a clear issue with the power cord and the printer.
You can get the power cord replaced free from Kodak.
As far as the printer goes, you can check with Kodak about the warranty period.
Oct 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The WII does not turn on, what do I check to fix it?
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 12, 2009 | Nintendo Wii Console
No Power to HP All-In-One 7310xi
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab102
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
NO POWER -lexmark X83
Then you must assume that:
1. Either the AC adapter is faulty
or
2. There is no power from the socket you the device is connected to
or
3. AC adapter is not connected properly to the power socket and the printer
or
4. The 'transformer' inside the printer has blown
Scenarios 1, 2 and 3 are easy. Scenario 4 requires either you return the printer to Lexmark and they repair it, or you purchase another printer. If it's still under warranty, contact them. If it's not, think about getting a replacement from another manufacturer.
Apr 09, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
What do error codes 3501,3502,3515 mean?
1. im not exactly sure
2. from the factory?
3. call 1.800.421.6699
also, i think the codes are related to your printhead
Jan 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
MP830 will not power on
Here is what Canon has to say:
Solutions for Printer won't power up Issue: The device does not power on
1. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source 2. Disconnect the power cord and wait approximately 10 minutes 3. Press the ON/OFF button to power on the multifunction device 4. Disconnect and reconnect the electrical cord to ensure a secure connection 5. The MP830 may require repair 6. Try a different electrical source / outlet
Here is a snip of my notes on the same subject for an Epson printer:
Well, first things first I guess:
  1. Try the printer in a different outlet (other side of room, or similar, not same power Jack)
    1. If you have power here, your issue is likely the outlet, not the printer.
  2. If the power cord has an "on" LED, check to see if it is lit up while plugged in.
    1. If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
  3. If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
  4. You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
  5. The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, but I can't tell from the Canon site if this printer has one or not. (It would be a black box between the plug and printer.)
    1. This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
      1. If this is the case you will want to contact Canon if the unit is still under warranty.
-Hope this helps.
May 27, 2008 | Office Equipment & Supplies
KODAK DX6340 won't power up
IF you still have warranty - then back to the store or Kodak it goes. If it is out of warranty - check Kodak site for tech help- they may offer a swap out for a low price.
May 13, 2007 | Kodak EasyShare DX6340 Zoom Digital Camera
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
55 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
