Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Soap still in drawer
Iturned my washer on and when it was done my powdwered soap was still in the drawer. I did three loads the same way earlier and now it leaves my soap.
  • 641 Answers
Does the soap at the drawer wet or dry ?
Posted on Jul 30, 2007
SOURCE:
Samsung vrt washer
The dispenser drawer needs taking out and cleaning, needs to be done more frequently in hard water areas. It will slove the problem.
Jul 22, 2014 | Samsung WF337AA Front Load Washer
Wcvh6800j1ww leaking under soap dispenser
Three screws at the back of cover, three screws at the front, push the cover back and you can remove it. 1 screw at the front of the soap drawer and two more on the dispenser and you can lift the whole unit up.
Sep 24, 2012 | GE WCVH6260F Front Load Washer
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
Can you use granular soap and where to apply it? we have a frigidaire washer with a drawer to put liquid soap in.
On our washer there is a little slider in that drawer that allows the opening into the washer to open wider for solid laundry soap. Maybe that's the case in yours. If not then you might be confined to using HE liquid soap.
Mar 05, 2011 | Frigidaire ATF6000ES Front Load Washer
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water is backing and flooding out the front from the soap drawer.
Sounds like this is the case check your hose from soap drawer that feeds drum, may need unblocked.
Apr 13, 2010 | Kenmore Elite 45986 Front Load Washer
Cant open soap drawer on washer
I opened up the top of the washer by unscrewing the screw in the back. then I pressed down hard on the white plastic cover of the soap dispenser that you will see on the front left hand side of the machine. I also moved it slightly to the right by pushing on the side of the same unit.
The soap dispenser then opened up fine. I cleaned out the soap dispenser from any crud that developed in it. Now it opens and closes nicely.
Did you know there is a class action lawsuit against LG for mold that develops inside of this model washer? I joined in the lawsuit. There should be no mold accumulating in any washer.
Sep 07, 2008 | LG WM-1485FHD Front Load Washer
Soap dispenser not working
It sounds like the water valve has a clogged filter.  Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve.  Clean out the filter with toothbrush.  Reinstall and everything should be ok.
Feb 18, 2008 | LG WM-1485FHD Front Load Washer
Opening the top of front load LG washer
to get your lid of the washer there are 2/3 screws at the back right under the lip of the lid once you have taken the lid of u will see the top of the soap drawer u can sometimes get into these by undoing the clips on either side of the soap drawer if u cant do it that way only other way is to make sure your soap drawer is closed properly and hit it hard at the front it should dislodge more than likely your conditioner drawer
Aug 15, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
