-   it keeps logging on and off and it flashes the desktop briefly. how do i fix this??-   Guest
Apr 06, 2009
-   Hey I have the same problem with my laptop. My laptop keeps logging off everytime I log in! :( Is there any solution for this? If not then how can I save all the important file from the harddrive. Any ideas?
-   Guest
Mar 25, 2009
-   my computer won't accept my password in safe mode -   Guest
Mar 24, 2009
-   after i log on to laptop it immediately displays the logging off message. i tried options in safe mode but unsuccessful.-   markeverhart
Mar 04, 2009
-   same problem someone please help ..I know its a virus but I cannot find a way to stop this. I have 2 hard drives so I can see everything but my documents because password protected so I dont want to reinstall the OS.please help
-   Guest
Boot your computer in safe mode,right click My Computer>properties>Advanced>uncheck"Automatic restart" under System Failure.
Scan your whole computer in safe mode then restart normally.
1. You need to connect the infected computer to a network. Make sure
that there is one computer in the network which doesn’t suffer from
this problem. Now, switch on both of the computers, i.e. the infected
and the working computer. 2. From the working computer, Go to Start> Run, type regedit.exe and hit enter. This will launch the registry editor.
3. Go to File> Connect Network Registry, by using this infected computer’s name or IP address.
4. Locate the following entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\
5. In this entry there is a key named userinit, double click on the key and set its value to “C:\WINDOWS\System32\userinit.exe,”
If the problem still persists then you need to run a repair setup.
Check out for detailed instructions on running a repair setup over here.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D600 PC Notebook
my pavilion dv2000 will not boot up past start up screen. can i download a boot disk or recovery...
(More)
my pavilion dv2000 will not boot up past start up screen. can i download a boot disk or recovery disk for this laptop
