Question about Garmin StreetPilot C330 GPS Receiver
Boot problems after discharging my battery
After a complete discharge of my battery over weeks and a reload, my Garmin shows a hard disk error with the hind to send the unit to a Garmin service center. Do I have any chance to repair the disk like in a PC? Thanks for help
Computer can't dectet the hard disc
Posted on Aug 21, 2008
  • 504 Answers
If your unit needs servicing, your best bet is to contact Garmin. It is not set up similarly enough to your PC for you to be able to repair it.
Posted on Feb 10, 2008
SOURCE:
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
Mar 28, 2017 | Garmin nuvi GPS
Garmin 530 log on problems
Could be a problem with the memory card. Please try to remove that then power up and see if the issue is resolved. If not, it could be a problem with the internal circuitry. If this is the case, then unfortunately, there is no other go except to get the device service.
May 24, 2008 | Garmin Rino 530 GPS Receiver
Tip
How to test battery-powered time
Battery Mark test principle is to use the built-in four engines to simulate the actual operating conditions to consume battery power. This four engines are the Graphics engine, Processorengine, Diskengine and Thinkengine. ".Graphics engine built-in Battery Mark by calling the procedure a sample LCBTP03003, such as Photoshop, Dreamweaver, etc. to simulate the actual use to deal with graphics, web pages and documentation process.
Processorengine to CPU occupancy rate increased to 100% instantly and maintain a period of time to simulate the CPU high load power consumption of under working conditions.Disk engine through repeated read and write operations on the hard disk to simulate the actual use of the power consumption of these drives on VGP-BPS8 VGP-BPS9, when you can see the hard disk light flash in the mad.Thinkengine is a simulation of the actual situation of users in the process of thinking.
Test, Battery Mark will be in the 4 cycle engine, constantly switching between Pavilion dv2000 Battery Pavilion dv6000 Battery HSTNN-LB31, followed by testing a variety of operating environment, this four engines can be fully integrated with the specific circumstances of the test battery. Each had 2 to 3 minutes Battery Mark test data will be automatically saved to the user to set the directory below. Completely exhausted the battery, the computer automatically shut down the last time before the results will be saved as the final test results. 4, repair laptop computer batteries methods
(a) causes damage to the battery,
notebook computer battery life is longer, often dissatisfied with battery charge, and even show the battery has been damaged, concrete expression of the resistance is bigger, at charging voltage is increasing relatively quickly at both ends. So easy to charge control circuit has been judged already been filled powerbook G4 ac charger powerbook g4 power charger, the capacity also falls. Since relatively large battery internal resistance, discharge voltage drop big, fast, so the system is easy to mistakenly believe that voltage is not enough electricity shortage. The discovery of relatively short battery life, should take appropriate measures.
(B) The battery refresh program to restore the battery discharge time
Big-brand notebooks have a battery refresh program, we can use it to repair the battery. For example: a IBMThinkpad390/262650-based notebook computers, are fitted with nickel-metal hydride batteries (Ni-Mh) batteries, due to normal charge and discharge properly, leading to the Pavilion dv2000 Battery and Pavilion dv6000 Battery discharge time is shorter, leaving less than 5 minutes, if the bring notebook computers to work, then it is very inconvenient, what methods can restore the battery discharge time then?
In response to these circumstances, we can use the IBM has launched a battery refresh program to refresh the battery put it back in discharge time, specifically as ibook g4 charger APple A1021 charger.
(1) the use of AC power to the notebook computer, first to ftp://fip. pc. ibm. com / pub / pccbbs / mobiles / isbr01ww. exe download software provided by IBM notebook computer batteries TP390/390e/390x refresh program. Wsvk
Ray (2), restart your computer, press F8 key to enter boot menu and select safe DOS mode.
Ray Pride (3) into the directory where the file you just downloaded to Compaq laptop battery, the implementation of the battery refresh program isbr0lww, exe, reading a warning message, by asking you to insert a floppy disk, and then press the Enter key to the implementation of the self-extracting operation.
Ray Pride (4) boot floppy disk with this computer, the screen appears StartingPC-DOS. . . Tips.
Ray (5) Follow the prompts to unplug the AC power to Apple, the program will automatically pairs of Ni-Mh battery discharge, discharge is completed, the system will automatically shut down.
(6) due to the battery temperature is higher at this time should not start immediately Sony VGP-BPS9, so that the battery cool for a while, the plug in AC power.
(7) to guide the computer with the floppy disk, this Autoexec. bat file will run automatically refresh program, and asks the user whether to proceed. Select yes, press the Enter key.
(8) At this point into HP, refresh program began to refresh the battery, the process quickly, when the return to DOS prompt A:> when that refresh has been completed.
(9) Turn off the computer, and recharge the battery until the green indicator light up.
Ray Pride (10) The above procedure repeated three times to get the best results.
Also, many battery pack lithium battery failure is the failure of a power-saving result of the core, this phenomenon can not be avoided. Because each section of the battery core properties can not be fully consistent with some of the quality of somewhat less long after the beginning of aging and the undermining of the whole (series after) the discharge curve to Acer BTP-58A1 Acer LCBTP03003. Interest and ability readers can try to open the battery pack, in the multimeter's help, you can quickly find the damaged batteries (abnormal voltage). If conditions permit, according to the corresponding parameters of the replacement batteries can be qualified product.
on Jul 30, 2010 | Computers & Internet
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
DELL 5150 hard drive error 7
Error code 7 means that your hard disk drive failed and is defective. As for reloading windows XP, I wouldn't. It's not supported by Microsoft any more. I would load Win 7 after replaceing the drive.
Feb 20, 2012 | Dell Dimension Computers & Internet
N5010 battery issue
i can advise u few steps to make the battery life better
1. drain battery completely then charge it
2. run a battery self test (charge and discharge battery 3 times)
3. switch off wifi and bluetooth when not in use
4. scan pc weekly to check for virus
5. use power save option
6. shut down when not in use or atleast put to hibernate
Feb 13, 2012 | Nokia N Computers & Internet
Garmin 1260T blankscreen?
Try pressing and HOLDING the power button for up to 15 seconds (or until it powers up - whichever happens first). This is a "hard reset" and should get you going unless the battery is discharged.
Oddly, batteries can discharge when the GPS remains on the car charger. Disconnect it and connect to the your computer's USB port (or AC adapter if it came with one) over night. The computer must be ON - "sleeping" is ok too - just not "OFF". This will charge the internal battery.
If it will not accept a charge, you may need to replace the battery or return the GPS to Garmin for service.
Nov 19, 2011 | Garmin nuvi 255W GPS Receiver
Window gets stuck on "disk
It is clear your hard disk has developed errors.
Let the disk check run completely. If is stops in the middle, that shows their is a major problem with your hard disk.
If you cancel the disk checking, the computer hangs because some of the system files are already damaged due to the hard disk error.
One thing you can do is to backup everything and format the hard disk and reinstall the operating system and the software.
If the hard disk error is propagating type (i.e. the amount damaged keeps increasing), you will have to reinstall the OS every 2 to 4 weeks.
In this case it is better to replace your hard disk.
Sep 11, 2011 | Acer TravelMate 290 Notebook
My garmin nuvi shows the Garmin name thenpowers off immediately. I can not do anything with it because it does not stay on long enough
Glad to HELP YOU!
This problem usually appears when the battery is COMPLETELY DISCHARGED. So your device doesn't have enough power/energy to complete the booting cycle = to TURN ON.
Take out the battery [if possible] and clean all connectors [the golden metallic tiny stripes] with a dry soft cloth.
Re-insert back the battery and make a complete CHARGING CYCLE.
Then try again.
If the problem persists you have no other choice but to buy a new battery for your GPS device.
GOOD LUCK!
Apr 15, 2011 | GPS
Trying to charge my Garmin 396 with external power. The unit is showing "Battery Missing". However my battery is there.
I had this problem on an aftermarket battery I purchased last year. It worked well for several months but recently gave me the battery missing warning and would not operate the unit at all. I checked the voltage on my Garmin OEM and on the new one. The Garmin OEM, showed 8.1V on two readings, between the center and right terminals and about that between the two outer terminals. The OEM showed around 5.7 so that implied that it had some bad cells and not a broken wire. I tossed it and bought a new aftermarket unit last week. That one doesn't show a full charge and when I switched back to the Garmin battery it shows 00:00 time remaining, but still 8.1V. Maybe I should have just bought a new Garmin battery!
Jan 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
Garmin StreetPilot C330 GPS Receiver Logo
66 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
