Question about Canon PIXMA MP130 All-In-One InkJet Printer
Problems with paper feeder-wont feed through-chews up paper
My paper feeder in my canon pixma 130 has stopped working-paper goes in and is chewed up almost at once-printer doesnt feed paper through-just keeps bringing up 'paper jam' It was working fine up until today-tried using photocopier and the result is the same-paper just wont feed through
help!!
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Posted on Feb 01, 2009
Paper is pulled sideways infrom feeder....
Look for possible dirt or sticky material in the roller. use some methy spirit to clean the rollers that take up the paper.
Check if there is any paper stuck on to the rollers, if so remove and clean.
Check if there is any wearing of the rollers, alignment of the rollers.
Finally use printer paper as thin paper might be chewed in.
Hope you check with my advice.
Aug 21, 2010 | Canon PIXMA MX310 All-In-One Printer
Feeder problems with Pixma 9500
By having a certified technician do a cleaning on the feed rollers this should fix the problem.
Jun 04, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Printer chewing the papar
This is due to problem with paper feeder roller. Replace the will resolve your problem.
Revert back for more assistance.
Feb 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
PAPER WONT GO INTO FEEDER STRAIGHT-GOES WONKY
One of the feed rollers may have ink or some debris on it. Get a lint free cloth and put some alcohol on it and clean the entire roller set, all the way around if possible.
Feb 07, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Paper keeps getting jammed in MP460
I had the same paper feed grabbing problem on pixma MP 610 printers - take a flashlight and look down into the feed rollers inside - deep - I found a paperclip in one and a hair clip in another - you need a pair of very fine pincer pliers to extract so you dont damage the roller assembly's made of plastic - and voila no more misfeeds and grabbing on the right side - hint - dont put anything on top of the printers because when you lift the scanner cover, it nicely slides anyting on top into the paper feed assembly and results in a jam
Steve
Aug 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Pixma ip5000
I had identical prob with a PIXMA IP4000. Eventually solved by turning upside down removing bottom feeder tray and gaining access to the four rubber rollers which pick up the paper. I rubbed each one with light sandpaper to roughen up the rubber, turning each one by hand trying to try to abrade all the surface. It did the trick.
Oct 03, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Sheet feeder isn't working
which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
462 people viewed this question
old marine
old marine
