Question about Epson Stylus CX5000 InkJet Photo Printer
Cant connect printer to computer
Computer does not have a place where i can insert a cd to connect my printer to my computer, how can i do it? its an epsom stylus sx405
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    You don't have a CD ROM drive?
    Sergeant:
  • 183 Answers
If you computer does not have CD/DVD drive the you can install driver from your external harddrive (Pen drive etc).
just find one of you friend who has computer with cd drive then copy all files and folder into your external storage device and plug it in to your computer then install it.
you should be good to go now.
if even this is not possible then download driver from manufacturer websit in to your computer and install it.
Good luck
Posted on Feb 07, 2009
How do i install or connect my printer on my PC
HP printers have come with an installation CD for as long as I can remember.
- Insert that CD into your computer,
- Start the installation (either via the auto start after you put the cd into your computer or manually browse to the setup file on the cd)
- Follow the steps of the installer and make sure you choose the correct options which apply to you.
Hope this helped!
Mar 04, 2015 | HP Deskjet D2660 All-In-One InkJet Color...
Red light blinking
The Attention light is flashing red.
Solution The printer requires attention. Try the following:
* If the printer is connected to a computer, check the computer screen for
instructions.
* If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the
CD/DVD tray now.
* If you have a digital camera connected to the printer, check the camera screen
for instructions.
* If the printer is not connected to a computer, check for the following problems:
- Main cover open - Out of paper - Paper jam - Print carriage jammed or stuck - Print cartridge missing or inserted incorrectly - Print cartridge tape not removed - Incorrect print cartridge installed - Packaging materials are not removed * If you are unable to solve the problem by using the instructions above, turn off
the printer and unplug the printer power cord. Wait 10 seconds, and then plug
it in again. Turn on the printer.
Feb 18, 2014 | HP Photosmart D5160 InkJet Printer
I want to connect my new computer to my printer
You mean connect printer to computer .
Before connecting the cables , insert the install disc in the computer drive and follow instructions . When installation os software/driver is completed , connect the USB cable to computer and printer and power cord from printer to AC plot . Press the power button and wait for Windows to confirm installation is successfull .
You can now use yoiur printer .
Best regards ,
fanaudi .
Aug 13, 2011 | HP Deskjet 2460 Printer
I cant setup printer and computer dont detect printer
Hi, this is how to setup your printer on your computer;
-You should have the printer cable which is working and the installation CD that came with the printer.
-Insert the CD into the computer and open the icon named setup and follow the on-screen menu.
-After the setup is complete, connect the printer and power it on for it to install
-If it connects you are done , if not check the cable connections and make sure it displays on the printers and hardware part. You can check this by clicking start and pointing mouse to that icon on windowsxp.
It is always good to print test page after installation.Good luck.
Oct 13, 2010 | Sharp AR-5320 Black and White Copier
How do you connect the printer
NOTE: To ensure that the software is installed correctly, do not connect the USB cable until it prompts you to connect it
Insert the green Windows CD into the computer after it
has been turned on and started up.
Once the USB prompt appears, connect the USB cable to
the port on the back of the HP All-in-One, and then to any USB port on the computer.
1. Lower both the paper and the print cartridge door.
2. Connect the power cord and adapter.
3. Press ( On button).
4. Open the print cartridge door. Make sure the print carriage moves to the center.
5. Remove the tape from both cartridges.
6.
a. Hold the cartridges with the HP logo on top.
b. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Make sure you push the cartridges in firmly until they snap into place .
7. Close the print cartridge door.
IMPORTANT: Wait a few minutes while the alignment page is printed automatically.
8. After the alignment page is printed, place it face down on the glass as shown in the picture. Close the lid.
hope this help
Sep 09, 2010 | HP DeskJet F380 All-In-One Printer
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
How do i connect my samsung nc10 to a printer
@Shakthi_v770: His computer does not have a cd-rom drive. It's a netbook! Furthermore, what if the printer in question was an older model with parallel interface? You can't just assume everything is plug-n-play. You need to ask some relevant questions first.
At nigellongsta: What kind of printer do you want to connect? Please provide the manufacturer and model of the printer
Dec 01, 2009 | Samsung NC10-14GW Notebook
Can you connect an Acer Aspire One laptop to a HP Deskjet D2445 printer? How?
Access the web-site for the printer's manufacturer:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3317539
and click "Getting Started" (connecting the printer to a PC).
Follow the instructions.
Nov 18, 2009 | Acer Aspire One PC Notebook
Cant connect to my computor i have no install cd
After connecting the usb cable from printer to the the laptop switch on the printer and then install the printer in the laptop by inserting the printer driver CD that came with the printer
May 28, 2009 | HP PhotoSmart 1215 InkJet Printer
Printing through wireless
hi,
if you had the printer before using the USB cable. then you changed it to wireless, try the ff:
1. re-insert the CD the came with the box, the cd that you used to install the printer Software to your computer.
2. after inserting the cd, it will give you option "add a device".
3. click on that to install the printer driver for WIRELESS.
note: the reason why you cant print, is mainly because the printer driver you have is still for USB connection. so inorder for you to be able to print, you need to install a printer DRIVER for wireless... That should WORK..
adonscott
HP TECH
Jun 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Stylus  CX5000 InkJet Photo Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
