Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens about 18" and stops
3 year old Liftmaster 1/2 hp
Manually door opens fully
No flashing on LED/learn button
  • khhelpme Feb 05, 2009
    Same problem, and it appears to be the belt. It's taut on one side of the rail and slack on the other. Should I disassemble and reassemble the belt?
    President:
  • 2,976 Answers
Check the drive belt for tightness. Check for a bent or obstructed track. Overhead door openers have a safety clutch built in in case something or someone gets into the path.
Posted on Feb 01, 2009
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
I have a 5 year old Liftmaster Professional 1/2 HP garage door opener. The door raises fully when the remote is pushed. However once the door is in the up position, when any of our car remote buttons are...
It sounds like you have a saftey sensor problem. Those are the black boxes on both sides of the door.
First make sure that the L.E.D. is illuminated on both sensors. If not, make sure that the lenses are clean and that they are pointed at each other.
This should be the problem, that is the light flashing rapidly, telling you of the fault.
Hope this helps, Matt
Dec 10, 2010 | Garden
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman garage door is about 8 years old. It
Make a slight adjustment to the Upward force on the side of the machine. Turn the screw a 1/4 turn each time and test, see if that helps. Also, make sure there are no obstructions or friction when the door opens and closes. Try it manually first.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
207 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
