Question about GE JKP45 Electric Double Oven
After Self-Cleaning the lower oven wont heat up!
After I had cleaned the lower oven with its self-cleaning, it stopped working. The electrical panel is fine and it sounds like its working. But after waiting long enough the temperature never increases. I need some help. Nate Faurer
There is an overheat sensor that may have failed to the open position. It is a little round button thing a little larger in diameter than a dime with two wires. Check to see if it is in the open position
Posted on Jan 06, 2008
After self cleaning now won't heat up
Self cleaning superheats the oven to burn off the dirt to ash. Unfortunately it can also burn out elements and the wires that are attached to the elements.
Disconnect again and check the timed oven settings. If no go, you need a service engineer.
Apr 16, 2016 | GE Profile JT952 Electric Double Oven
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2010 | Thermador SC302T Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
GE JKP45 Electric Double Oven Logo
117 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
