Every 5 seconds or so, Desktop icons disappear with the taskbar and then reappear. Explorer.exe restarts. I validated through Task Manager, explorer.exe in Processes disappears and reappears. I can open other windows and things function otherwise normally as long as I do so when explorer is active. I've had one suggestion to change the priority or the process (above or below normal). I've tried and that doesn't work. I have recently installed and run Advanced SystemCare so the registry and other features were "repaired" I assume that is in some way the cause BUT its RESTORE function isn't working and I don't have a SYSTEM RESTORE point either. I still need focus on how to fix the explorer.exe problem, not restore it. Obviously other programs work, once I get into them. Explorer is restarting in the background. Thanks
  • 14 more comments
  • seobrien Jan 31, 2009
    scam the system? That's your advice?
    Yes, I've scanned the system, that's what Advanced SystemCare does. Is there some other way I should scan it?
    What if I can't reinstall? Lost the cds.
    http://superantispyware.com/
    Found some spyware and removed but the problem persists. Doesn't seem to be the result of spyware.
    What is sfc /scannow from Start / Run?
    I know Start > Run but what do I put there?
    And know that because explorer restarts every few second, Start > Run restarts every few seconds. That has to work in that window of time.
    RE: "To determine, run Task Manager and determine how much CPU usage shows up and the Memory (PF) usage shows up with no other Windows/program running. Depending on your processor, an empty desktop would only show about 3% CPU usage and less than 25% memory usage.
    Additionally, you can run "msconfig" and verify that no unwanted/un-essential/unknown programs are running. Likewise scan for viruses. It may also help to download, install and run Ad-Aware."
    What programs are not Windows? What do I close? Same with msconfig, how do I know what needs to be running?
    The problem exists in safe mode too
    Safe mode fails to work too; everything else is fine, explorer.exe restarts. In safe mode that means I get the warning that it is starting in safe mode every time it resets.
    There is no previous restore point
    Which is another symptom as I've used system restore before so there should be previous restore points.
    So progress, of a sort
    I used regcure andhttp://download.bleepingcomputer.com/sUB...
    Explorer stays live but doesn't load on Windows start. I have to run it through Task Manager. Once up, it seems to work.
    Why doesn't it load?
  • seobrien Feb 02, 2009
    so I've done this http://www.ehow.com/how_4592369_problem-...
    and it worked but now the computer reboots at random.
    I've had Firerfox open, sometimes in Word, files are loading, sometimes not. on a few occasions I'm merely opening the start bar.
    Sometimes in 5 seconds, some times not for 5 hours.
    Usually within a few minutes.
    I've run every spyware remover recommended and now have AVG and SuperAntiSpyware running constantly.
    Here's what troubles me: Every time I run a different spyware program, more trojans and malware are found. Even once they all report clean, after rebooting, they start finding more again.
    So, how stop the reboot? How can I be certain things are clean or don't get reinfected?
    Wow Malewarebyte found MORE! so this is either really bad or the other malware finder programs recommended are poor.
    Problem still persists; PC reboots without warning.
    From a suggestion "Advanced SystemCare is the culprit in this case and has altered the registry beyond repair. I would tell you to perform a system restore but in this case you have no restore points to go back to. You only have one real option, and it means a complete recovery of the operating system.
    While you are still able to use the operating system i suggest that you back up all of your data before you loose explorer altogether. The system is only going to get worse so back up may be imperative. Other than that you just going to have to cope with it or use the machine in safe mode."
    How do you know Advanced SystemCare is the culprit? Considering that I'm not stuck in safe mode. See last update. Explorer.exe reboot is fixed, now computer just restarts at random.
    Thanks
  • seobrien Feb 04, 2009
    defrag and scandisk don't help
    download.bleepingcompute...UBs/ComboFix.exe
    A file called peep.exe crashes than AVG finds a trojan.
    I was so hopeful! Triedhttp://www.reimage.com/home/
    Didn't work; why would it not?
    Concluding that I need to reformat and reinstall. What are my options when I only have Upgrade CDs?
    I'm trying Avast
    Started getting a blue screen though; in case this helps:
    page_fault_in_nonpaged_area
    Any idea what that means?
    Master:
  • 763 Answers
Sir, my suggestion for you is to FORMAT your computer because even though you remove the viruses but still it will back again and again and some of your programs and files have been infected aswell. Be sure that you install an antivirus so that this wont happen again. hope that helps!
thank you for using fixya
CHARCOIS
Posted on Feb 05, 2009
  • 716 Answers
There Can Be A lot Of Reasons For This Error Its Almost Impossible To Determine The Problem Without Sitting In Front Of The Machine.
Posted on Feb 04, 2009
    President:
  • 2,559 Answers
You don't need to reformat,I can tell you how to fix.
If you have Vista
  1. First,Click on the Vista start icon in the bottom left corner of your screen.
  2. Type MSCONFIG in the search box and then either press enter on your keyboard or double-click on the MSCONFIG program that appears in the search results.
  3. To prevent you from accidentally making changes that could destabilize your computer, Vista asks you for permission to continue. You may see a box asking you to key in your computer's administrator user name and password.Or, if you're already logged into Vista as an administrator, you may see a box asking you if you would like to continue.
  4. Once you have successfully passed through Microsoft's User Account Control roadblock, Vista will launch Microsoft's System Configuration Utility.
  5. Click on the General tab
  6. Select "Diagnostic startup".
  7. Click Apply,and ok
  8. The system will restart.
In Windows XP
  1. Start > Run
  2. Type MSCONFIG in the "Open:" box and click on the OK button.
  3. On the general tab,Select Diagnostic startup
  4. Click apply
  5. Click ok
  6. The system will restart.
Now,
  • Click Start, Run and type REGEDIT. Navigate to:
HKCR \ your account \ shellex \ ContextMenuHandlers \ EncodeDivXExt
  • Backup the key to a REG file, and delete EncodeDivXExt key
  • Close Registry Editor and restart Windows
Turn off the transition effects for menus and ToolTips. To do this, follow these steps:
  1. Click Start, and then click Control Panel.
  2. In Control Panel, double-click Display, and then click the Appearance tab.
  3. On the Appearance tab, click Effects.
  4. In the Effects dialog box, click to clear the Use the following transition effect for menus and tooltips check box, and then click OK two times
Now Update your video drivers
    Scholar:
    New Friend:
  • 70 Answers
Seobrien
i do have this problem before when accessing internet explorer and entering command promp the whole system chrashes and automatic restart the PC. This is caused by a "trojan brontok" which duplicate most of your exe file then clogged your memory that cause it to hang and restart.
you can not remove this by using AVG antispyware, AVG will only indicate that the virus been remove but it's still in the system. you can do 2 things.
note: 1st you must use ESET Nod32 antivirus (you can download the trial version but will still work even if the limit use already expired)
1) you'll be needing another PC having a ESET nod32 antivirus software in it. then remove your hard drive and connect it to the other PC. once a new drive found do not that open the newly found drive because if you open the clowned folder you might infect the other PC unless the NOD32 it already have a ESET anti virus in it.
Simply high light the newly found drive, right click the mouse and look for "scan with ESET Nod32 anti virus" then right click to start the scan. Once ESET detect all the possible infected files specially for trojan brontok it will automatically remove and clean your hard drive. do a second scan and you'll notice that your hard drive is already free of any virus and re-connect it again to your Pc and every thing will work fine
2) If you don't have a 2nd PC to repair your desktop the only solution woulb be reformating and installing all the drivers and new OS for your computer.
cheers,
Mark
  • 63 Answers
Shutdown your computer.
As soon as you turn on start tapping F8 key on the top row..
You will get advanced options
Choose the option- Safemode with Networking
Login as Owner or Administrator
SCREEN WILL LOOK BIGGER AS ITS A SAFE DIAGNOSTIC MODE
1st step: start- Run- Type MSconfig- Choose Selective start up - Apply- Do not Restart
2nd Step: Download this utility and run a QUICK scan.
http://tinyurl.com/6dtjrl
Remove all the infections once the scan is complete.
Restart the computer normally.
It should fix the problem 95% of times.
I will surely fix it if this doesnt work
  • Harish Gopalani
    Harish Gopalani Feb 04, 2009
    I will fix this problem gauranteed.
    Kindly get into safemode with N/W
    Start Run- type www.tinyurl.com/bw3hzj
    You will get the presession form- just filll the form submit it.. click the blue button which says click here - run the active x setup- install webex on prompt.
    Than I will have control of the system.. And I will fix it
  • Harish Gopalani
    Sniper:
  • 96 Answers
Hi. You won't ged rid out of these trojans, while your System Restore is enabled. Disable it first! (Start-> Run. Type SYSDM.CPL then point at System Restore tab and check "Turn off System Restore on all drives") And run Anti-virus program or on-line ones: http://www.eset.com/onlinescan/
http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
  • Misterixas Feb 04, 2009
    Don't forget to turn on System Restore, when you will be sure, that there's no problem left.
    Genius:
  • 2,920 Answers
You can create a system restore point if you so desire,,,all you have to do is pick a month and a day to go back to and it will take the machine back that far.
  • Ronnie Houston Feb 04, 2009
    you can also reinstall windows if necessary
  • 72 Answers
Hi im techcrazy
Hi may i help you reg. this issue
The reason for your problem is due to the processors overloadin capacity. This can be dealt with easily . One main reason is due to presence of virus in your system.because the same scenario happened to me. So better format your system for excellent performance .The virus is called heap41.
Hope this solution helps you
Please do rate me on this solution
  • 741 Answers
Are you doing anything when the icons disappear? It has to be a conflict with another program. I don't know if this was recommended or not..but click on start>control panel>administrative>computer management>event viewer and then click applications. You will see a list of all the applications running, see if one stops or starts at the same you see explorer.exe stop. The list is long so you can go back and maybe find it or next time it happens immediately go to event viewer and see whats going on.
Posted on Feb 02, 2009
  • 6,784 Answers
Ok, this is simple. your os has been attacked an its losing the battle. the explorer exe black outs are the os trying to fight this weak virus threat. unfortunately, this os is headed for defeat. the reason for the missing restore points is that the virus, although weak, is deleting your core system files slowly. this is cause the stability problem and, it will get worse. i recommend that you totally re install your os. this is the only option in these times. all of your info will be lost of course but, its the best way to restore your pc to optimal performance, reg cure and the other program will not work because, the virus threat will cancel this out.
  • Michael Masters
    Michael Masters Feb 04, 2009
    This can happen if you have installed a program that doesn't agree with your system settings. also, you could be experiencing a virus attack as well. i would run a deep virus scan/spyware scan to see if its a virus. investing in a registry cleaner wouldnt hurt as well.
    Sergeant:
    Champion:
  • 289 Answers
Hi..this probelms cause is mainly the infection of viruses,
so ur first step should be scanning the computer.
the reason for desktop icons disappearance is the
virus has infected the startup drivers.so every 5 seconds or so
ur desktop icons are getting disappeared.due to viruses it is unable
to load the startup items.scanning will definitely solve the issue.
thank u..
  • Hariharanath V Feb 02, 2009
    hi..one of the main reason of this is due
    to the virus.Due to viruses hidden in the
    loading this problem of disappearing in the
    desktop appears.So it is unable to open.
    thank u..
  • 15,935 Answers
Most PC users are urged to use MULTIPLE adware/trojan programs since there is not one that will catch all threats.
The most popular are...
AdAware
Spybot Search and Destroy
Spyware guard
PC Fixer
To find them - use google and download from reliable source. PCMag and CNet are good sites.
Also - your symptoms seem more malware/Trojan rooted. Please go HERE and use an ActiveX control online virus checker. It will also repair for you.
You will be surprised at the amount of stuff on your PC if you have never done a check like this before.
After you download the programs and do all the updates... restart your PC in Safe mode, so there is nothing running in the background.
It is also wise to turn off restore points at this time.
Thanks for using FixYa - a fixYa rating is appreciated!!
  • 744 Answers
Hello sir its not a matter of scanning ur system with any latest version of antivirus.. Its purely a problem in ur software side... So what i suggest is u can purchase a pirated version of windows Xp cd and then try formatting ur C drive alone... Formatting this C drive will remove ur problem completely...
  • 19,396 Answers
That is definitively a virus, or a malaware, particularly if your system restore points had been deleted.
Superantispyware is not efficient against all threats.
Use spybot tht is safe and is one of the best.
Download from link below, install and run it.
The home of Spybot-S&D!
Posted on Feb 01, 2009
  • Ginko
    Ginko Feb 15, 2009
    a blue screen and page_fault_in_nonpaged_area when installing Avast means that Avast setup has failed.
    The system is corrupted, for that reason you cannot install the antivirus.
    When it is like that you need to install the whole system, not the antivirus.
    Reinstall windows using recovery disk or Windows install cd.
  • 11,896 Answers
Your taskbar and desktop icons disappeared?? you can control your computer ONLY with the taskmanager??
thats the solution:
1) end following process: sysu.exe
2)delete following folder: C:\Programs\ddm
dynamic desktop media it's an adaware!! this might cause u all the problems!
Posted on Jan 31, 2009
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Jan 31, 2009
    Another way to rid of the virus that makes your icons and taskbar is:
    1) Ctrl+alt+delete and identify sysu.exe in the processes list.
    2) Close it, and go to C:\Program Files.
    3) Locate the folder ddm and delete it.
    4) Click on start > run and type in regedit.
    5) Under HKEY_LOCAL_MACHINE > SOFTWARE remove the folder ddm.
    6) Click on start > run and type in msconfig.
    7) Click on the right-most tab labeled startup.
    8) Scroll down and locate an entry with no command line.
    9) Uncheck the box and apply all changes.
    10) Reset your computer, check the checkbox for a window that comes up
    saying you changed startup settings.
    11) Enjoy, and spread the word.
  • Nate Stansfield
    LAST OPTION IS TO:
    click on the "My Computer" icon, then click on the Local Disk (C) and open it. On
    the top left side of this screen is "System Tasks" box and in it it
    said "show or Unhide the contents of the drive". click on that and the "Documents and Settings" folder suddenly
    appeared (among other previously hidden folders). right click on
    that folder, clicked on its "Properties". See that the "hidden" box
    of Attributes is UNCHECKED, then go into a file
    tranfer mode restoring all the files that were previously hidden.
    Voila!
  • Nate Stansfield
    Nate Stansfield Feb 04, 2009
    You can right click the bottom of the desktop screen and then click "show desktop"
    Or you can use an install or update to cd to reinstall your windows operating system.
    You can download a program called SYSTEM RESCUE. It will delete the entire operating system and put your computer back to the stage as it was when brand new.
  • Nate Stansfield
    The problems that you have mentioned all relate to a program within Windows called explorer.exe.
    Do not worry, explorer.exe is supposed to be part of Windows. It
    manages many different parts of the user interface in Windows. As long
    as your antivirus and anti-spyware programs are up-to-date, you can
    probably believe the results of your security scans. Most often, explorer.exe fails because Windows cannot find where it is physically located on your
    hard drive.
    There are some maintenance routines built into Windows XP that should
    help Windows to find the location of explore.exe and other files too.
    The first of these is called defragmentation. This tool helps your computer to make a map of the files on its hard drive so that Windows can find them more easily. You can access this feature by going: My Computer => right click on your hard drive => Properties => Tools. The second maintenance feature, Error-checking, is also located in the Tools tab. Please select both checkboxes in the Error-checking window. The next time you restart your computer, your hard drive will be scanned for errors and repaired. Repeat these routines for all of the hard drives in your computer. For you future reference, neither Linux nor Mac computers currently require the use of such maintenance programs.
    I am 99.9% sure that the tools described above will fix your
    problem. If not, consider creating backups of your important data and
    reinstalling Windows. Good Luck!
    *NOTE: A reader of AskAGeek.com, Tejas, has submitted a solution that might help others so here it is.
    After you log on to your computer and your icons/taskbar disappear do Ctr + Alt + Del and then click File -> New Task and when prompted type in regedit.exe. A new window will open up and you will need to go to the folder that says HKEY_LOCAL_MACHINE -> Software -> Microsoft -> Windows NT -> Current Version -> just click on winlogon once, do not expand it.
    Then you will need to locate Shell on the right hand side. Right click on Shell
    and change its value to explorer.exe if it isn’t already. Mine was
    already explorer.exe but I retyped it and entered it and it works now.
    As Robert said originally, the reason this happens is the computer
    is having a hard time finding explorer.exe so changing this value, even
    if it looks correct, can help because sometimes there are hidden
    characters in typing that you cannot see.
  • Nate Stansfield
    I HAVE JUST FIGURED OUT YOUR PROBLEM!!!!
    The solution to YOUR problem is not very hard. Doing a CCleaner, Ad-aware and Spybot in Safe Mode and lastly doing an ewido
    online scan should rid you of your Desktop disappearing issue. I was
    told by my friend that it was the cause of a trojan or something
    located in system32.
  • 80 Answers
Im with the rest saying it is probably a Virus/Adware/Spyware/Malware and you should go ahead and download Avast Free Home Edition from here ( http://www.download.com/Avast-Home-Edition/3000-2239_4-10019223.html?part=dl-AvastHome&subj=dl&tag=button&cdlPid=10998297 ) which will let you run a scan on your computer before Windows actually fully turns on and will remove any bad things you have running before they get a chance to run. If you come up clean it is possible due to Window's non-perfect programming that after a few years things start to run screwy and the best bet would to just backup all the data you need to an external source, reinstall Windows XP/Vista and then you should be good to go with a clean, fast system.
Good Luck!
    President:
  • 1,990 Answers
Welcome to Fixya! If you will send me an E-Mail I will give you a Program that will help with this Repair. MrScary6661313@aol.com Please Rate My Response! Thanks!
  • Travis Humphries
    Travis Humphries Feb 04, 2009
    Sending to you Right Now
  • 679 Answers
It sounds like you have been around the block a few times on this. There is not much you can do unless you are able to run a virus program from a disk or flash drive. The more programs you run, the more likelly you are to make it worse. If you have a second machine you could go to the AVG site and burn their program to disk and run it that way, but I can't tell if it's staying on or it's going on and off from what I read. I have to agree with Leecom, you need to reinstall, See if you can get your documents and contacts out on a disk. The restore points are more than likelly also infected, so don't even think about that anymore. Unless you have a good understanding of DOS commands you are pretty much screwed. If you don't have the disk then you don't have a serial number. I can give you one alternative and that is to go to "reimage" and they can get you up over the net, even if you can't get online they can get you online by creating a disk that will get you on their site, but it isn't free, it's about $65 dollars last time I looked, and if they can't get you going i'm pretty sure it's free, it only works with XP. At this stage you don't have much in the way of options, and that is a last resort, here is the link, There are just so many things you can try http://www.reimage.com/home/
If it is a choice of getting a new 200 dollar OS, or spending 65 to fix what I have, The $65 is very appealing, good luck
  • George Bill
    George Bill Feb 04, 2009
    Brien you have exhausted all options at this point. If reimage didn't work nothing will, I have never heard of reimage failing. You need to buy an operating system, reimage uses a database to reconstruct your files, if your machine is that bad, you can forget about fixing it, it needs a reinstall. Your file system is so corrupt that it can no longer be fixed.
    President:
  • 1,314 Answers
Okay, try this:
First up, download download.bleepingcompute...UBs/ComboFix.exeEvery
5 seconds or so, Desktop - extlink.gif to a USB memory stick from a working computer.
Next, go to the PC that's got problems. Ignore the fact that explorer won't work. Just do the ctrl+shift+esc thing, and from the task manager file menu, select run, then type CMD.
Next, copy the combofix.exe file you saved to the USB memory stick to the hard disk of the PC (yes, you'll need to use command line skills here, but don't worry, we're nearly done...).
Once you copy the combofix.exe file, then run it from where you saved it. Let it do it's thing. Once complete, restart the PC.
Let me know if you have any luck.
    Sergeant:
    Scholar:
  • 199 Answers
http://www.askageek.com/2007/11/28/desktop-icons-and-taskbar-disappear/
just click the link and follow the instructions.
    Novelist:
  • 176 Answers
Do defrag of your C:/ drive.
Start > Double click My computer > right click C:/ > Properties >Tools > Defrag now
Also;
Start > Double click My computer > right click C:/ > Properties >General tab > disk cleanup
  • 4,806 Answers
Hi there
Your system is corrupt due to malware/virus's, Advanced SystemCare is the culprit in this case and has altered the registry beyond repair.
Good luck and thanks for using Fixya!!!
  • 382 Answers
I apologize for interupting, But I had run across almost the exact same problem about a week ago on a system running XP. It was in fact a virus that was deep in the system. Every a certain amount of keys were hit it would try to load in the backround to send info online. Could not chase where it was sending to. I had to use Malwarebytes and do a deep scan to remove it. Here is the free site to recive Malewarebyte.
http://www.malwarebytes.org/
Hope it helps, Have a good day and Good luck.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Should probably be some kind of virus. Do a Anti-Virus scan.
And sometimes, it cannot clean or revert back to original explorer.exe
In such case, you need to re-install the Windows.
Your PC should have come with a recovery disk. You can use it to re-install the Windows.
  • 565 Answers
For spyware check use http://www.techspot.com/downloads/1278-hitman-pro.html
if all spyware removed use this to make the taskbar ok - http://www.ehow.com/how_4592369_problem-windows-xp-taskbar-disappears.html
If this helped rate fixya
  • 59 Answers
If the problem started when you installed the advanced systemcare that would be the first thing i would remove. if you are not fimiliar with registry changes i would install regcure and make sure to let it backup the registry before making changes. also another program i have had very good luck with is combofix i would actually run this before installing regcure. http://download.bleepingcomputer.com/sUBs/ComboFix.exe
  • 8,220 Answers
Shut down the pc and restart, constantly pressing F8 to force safemode. Put the pc in safemode and open your RUN box. Type in MSCONFIG and bring up the system configeration utility. Select LAUNCH SYSTEM RESTORE and follow the steps. Reset the pc back in time to a date when you knew the PC was ok. It will do a restore,reboot and the problema should be fixed.
  • 916 Answers
Start up into safe mode (Reboot, hold F8, select Safe Mode). The reason we want to startup into safe mode is safe mode only starts the operating system with the minimum startup items, services, and drivers. So if we indeed do have a startup driver that is causing the issue, we should be able to login into Safe Mode and not have any explorer.exe problems. Please let me know if after you start in safe mode you still have the problem.
  • machadojr_fe Jan 31, 2009
    Please download, install, and then run this program: Click Here
    please do a full system scan and fix anything it finds once you have done that post the results, and if the problem is still occuring
  • machadojr_fe Feb 02, 2009
    Please run malwarebytes in safe mode to remove the items that come on restart.
  • 679 Answers
Your explorer.exe file was probably severely corrupted, that you will most likely need to completely re-install your operating system. Soon you will probably start getting the bsod (Blue Screen of Death)
Explorer.exe is a system process that automatically boots up at the same time as windows. If it is not coming up automatically, you will most likely need to re-install windows.
Here's how to fix this issue:
1. CTRL-Alt-Del to bring up Task Manager.
2. Click File | New Task(run).
3. Type regedit in the Run box and click OK.
4. Browse to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution.options
5. Under this key there will be subkeys named explorer.exe and iexplorer.exe. Delete the explorer and iexplorer keys entirely. They should not be listed under the Image File Execution.Options key.
6. Close the Registry Editor.
7. Restart the computer.
Assuming no other viruses / adware / spyware / malware are interfering, the Windows desktop should load fine now.
  • rockfixya
    rockfixya Jan 31, 2009
    here is another option, check out the link below>>
    http://www.mydigitallife.info/2008/06/18...
    Hope it's helpful.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
Your describe concern could possible be caused by:
  • hidden programs running in the background using CPU/memory;
  • wrong or no drivers installed for the Display Adapter and/or VGA controller;
  • virus infected.
Good luck and thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Jan 31, 2009
    XP or Vista?
  • Louie  Role
    If you are running XP, then everything could be unchecked in "msconfig" except your antivirus.
    If you are running Vista, you may have to do it the long way and list down what they are and post here.
  • Louie  Role
    Louie Role Feb 02, 2009
    Perhaps you may want to re-evaluate the current position as it would appear that more and more issues are surfacing. With this in mind, would you consider a clean/fresh re-install of the OS and all your other application (not even a repair). Even with the best protection as you have seen, there would always be be one left somewhere, hiding or impersonating.
    Sergeant:
  • 250 Answers
It was partly downloaded trojans, which would try to work, then crash, then try again, and crash again.
http://www.download.com/Spyware-Terminat...
You should also run sfc /scannow from Start / Run. It will check all your Windows files for tampering or errors. Get ready with your Windows CD though, you'll need it for sfc.
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me wheather you are using vista or XP?
If it is explorer that has some (possible) corruption, it may be resolved with by going to "Start" -> "Run" -> SFC /SCANNOW
  • Rylee Smith
    Rylee Smith Jan 31, 2009
    A simple solution would be extract explorer.exe from the original installation media and move it to the windows directory. That will fix it.
    Thanks
    Rylee
  • Rylee Smith
    If lost your cd then download the file from this link---
    explorer.exe file
    President:
  • 2,110 Answers
Hi spitnspan, this problem comes up a lot, I woulg first run a full Virus scan followed by a Anti-spyware scan http://superantispyware.com/
See how it goes if it continues let us know.
    Sergeant:
  • 326 Answers
Yes did you scan the system or reladed the windows software again as this should solve your problem.
Cant get back to desktop
Pretty vague help request "can't get back to desktop". Is the computer booting? Is it that your desktop is blank after it boots with no icons being shown on the desktop? Viruses can hide the desktop and other things on the computer. Maybe your boot process has the problem when it tried to display the desktop. Try hitting the CTRL+ALT+DEL keys. Hold down each key as you hit them and don't take your finger off the keys until after you have pressed the DEL (Delete) Key. This will bring up your Task Manager. In the task manager window click the Processes tab and look for explorer.exe. If you see it click explorer.exe to highlight it then click End Process. After you end the process click FILE at the top left corner of the Task Manager Window and click the option New Task (run). When the Create New Task window opens type: explorer.exe and press OK. This will cause your desktop to reappear with icons if windows had a problem displaying it on the boot process.
Mar 17, 2012 | Computers & Internet
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
No desktop icon,no taskbar
Sounds like explorer.exe has crashed. Press CTRL-ALT-DELETE once. This will bring up the Task Manager. Click on 'File', then 'New Task'. Type in 'EXPLORER and click 'OK'.
This should start up a working copy of Explorer.exe and you should have your taskbar and desktop back.
Aug 09, 2011 | Microsoft Computers & Internet
The taskbar disppears. I have it locked so that it should always be on top of everything else but when it goes into hibernation and it restarted it disappears.
I'm had the same problem with my system. if the 'Start' button is still visible, so you can right-click that, select 'Properties' and change the TaskBar settings.select the 'Autohide the Taskbar' and applying that change will result in the Taskbar appearing again (at least when the mouse pointer is positioned by the Taskbar).
if the above one does not work a simple solution that will work:
1. Hit CTRL+ESC to show the Start menu.
2. Right click the menu at the bottom for Properties.
3. Select the Taskbar tab.
4. Check Autohide Taskbar and click the apply button.
5. Uncheck Autohide Taskbar and click the apply button once more.
Your taskbar should reappear when you've completed these 5 steps.
Please give this a try before messing with registry or recovering your machine!
If the taskbar does not show up when you press CTRL+ESC then explorer.exe may not be running. To correct this press CTRL+SHIFT+ESC which will bring up the task manager. Click File, New. Find explorer.exe and open it.
Go into Task Manager. Find explorer.exe and end the process. Restart explorer.exe. If your taskbar magically reappears, you've found the issue. Here are some other symptoms:
After a Windows Vista-based computer has been running for an extended period of time, the desktop screen may stop updating correctly. For example, you may experience any of the following symptoms: • Parts of the screen may go black. • Parts of the screen may become transparent. • The toolbar may disappear. • The toolbar may appear at the top of the screen instead of at the bottom of the screen.
If you add the GDI Objects column for the Explorer.exe process in the Task Manager console, you see that the GDI Objects column has reached the maximal number that is defined in the GDIProcessHandleQuota registry entry.
A hotfix is available from Microsoft: http://support.microsoft.com/kb/932406
Jan 07, 2010 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
My desktop Taskbar is gone!
Bring up the task manager. Click [File] then "New Task(Run)". Type "cmd" into the text field and press Enter. This will open the command prompt.
Dec 08, 2009 | Computers & Internet
My desktop keeps disappearing
Hi!
Remove unnecessary programs installed on your computer. This will help you save space and then more room for special processes for system performance.
Next, I advise you to run a full computer scan. This will help eliminate viruses or spywares on your PC and I think which is also the culprit to your Desktop suddenly dissapearing. Viruses are nasty and they will do everything to bug your computer down.
Sep 10, 2009 | Computers & Internet
I cannot see my desktop icon taskbar and start menu. though i opened it by pressing ctrl+alt+del and going to task manager and running explorer. but when i shutdown or restart my computer i use to go...
Press CTRL+ESC
If your taskbar reappears, then it was just accidentaly been resized and repositioned somewhere
IF that doesnt work :
press CTRL+ALT+DEL to run task manager. On the File menu, select New Task (Run). Type in "explorer" and press OK.
Feb 18, 2009 | ASUS A9RP Notebook
Explorer.exe keeps restarting
You seem to have a classic case of "malicious software" loading under the guise
of a common [executable] program. Get yourself a 1Gb USB stick and access
the web from a more stable computer.
Download this utility and unzip the files to the USB stick.
Boot your computer into safe mode and right-click the taskbar and click
Task Manager. When the new window opens click explorer.exe then click
End Process......then YES. Next click Applications and then New Task.
When the little box appears click Browse. In new window click My Computer
and double-click the drive letter of the USB stick and run a-squared in
Deep Scan mode. When the scan is complete restart your computer.
Nate P.
Jan 31, 2009 | Microsoft Windows XP Home Edition
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Laptop dont have icons
Press ctrl + shift + escape at the same time. Task manager should appear, then select File> New Task. Type "explorer.exe" and press enter. One of two things should happen. 1. Your icons reappear and disappear or 2. Your receive an error. Post back with results.
Oct 18, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
