Question about Panasonic PT-51HX40 51" Rear Projection Television
Panasonic PT-51HX40 Wont stay on
I bought a tv for cheap but when you turn it on it only stays on for a second? Is this a hard fix? Do i need a repair man? Or can i do it myself? Little knowledge of electronics
  • Anonymous Feb 07, 2009
    My tv is mod # pt-51hx41e. 52 inch, purchased in 2002. I have the same problem.
    I turn on the tv, the red light stays on for approx 7 seconds, then powers off.
    Can i repair this myself, or is my tv finished?
    Please help.
    Edward
  • Rs3k Feb 10, 2009
    My Panasonic PT-51HX40 sounds like it is coming on for about 4 seconds, then won't. I was watching it when it suddenly quit, something obviously overheated, but I can't identify what it is.
Could possible be bad conections
I had a set that was doing that the bad conection was at the relay but you always check all conections
hope this helps
Posted on Mar 05, 2009
My tv wont turn on, the on/off light flashes as if it was going to turn on, It flashes green, then after 90 seconds, The on/of light turns red and stays blinking red.
ricrevolorio,
Your lamp needs replaced.
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will walk you through the process including where to get the lamp at the best price for the quality. It does not pay to go cheap.
Thanks for using FixYa and for the generous rating.
hardrocko
Sep 27, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a pt50lc13 panasonic that would not turn on. I bought the ballast repair kit and installed it and a new panasonic bulb. The tv now turns on, but only for about 5 seconds and then there is a click...
I'm not sure if this is the professional way:) -- but when my pansonic 1080i was acting up just like that - I placed a small fan at the back of the right side of the TV unit and faced it towards the TV air vents and voila the TV stays on and stays cooler. No more blinking lights. I don't think the cooling fan that draws the air out of the TV was working and the TV was overheating. Saved me some money in repairs and after a year it is still working well. A quick and cheap fix - but it worked. Jeanne
Jul 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
It shuts off all by its self but not all the time
If I was working on this set I would look for cold solder joints on IC501 Vertical output IC.
Sep 03, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Pt-51hx40
Needs convergence circuit repair = usually about 400.00......T.
Aug 07, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic pt-47x57 power does not stay on
You could have a voltage regulator problem with bad capacitors or a defective solder connection in the deflection circuits. A service call is needed to find out what is the cause.
Jan 24, 2007 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
