Question about Microsoft Windows XP Home Edition
Explorer.exe keeps restarting
Every5 seconds or so, Desktop icons disappear with the taskbar and thenreappear. I validated through Task Manager, explorer.exe in Processesdisappears and reappears.
I can open other windows and things function otherwise normally as long as I do so when explorer is active.
I've had one suggestion to change the priority or the process (above or below normal). I've tried and that doesn't work.
I have recently installed and run Advanced SystemCare so the registry and other features were ''repaired'' I assume that is in some way the cause BUT its RESTORE function isn't working and I don't have a SYSTEM RESTORE point either. I still need focus on how to fix the explorer.exe problem, not restore it.
Obviously other programs work, once I get into them. Explorer is restarting in the background.
Thanks
    Scholar:
  • 96 Answers
You seem to have a classic case of "malicious software" loading under the guise
of a common [executable] program. Get yourself a 1Gb USB stick and access
the web from a more stable computer.
Download this utility and unzip the files to the USB stick.
Boot your computer into safe mode and right-click the taskbar and click
Task Manager. When the new window opens click explorer.exe then click
End Process......then YES. Next click Applications and then New Task.
When the little box appears click Browse. In new window click My Computer
and double-click the drive letter of the USB stick and run a-squared in
Deep Scan mode. When the scan is complete restart your computer.
Nate P.
Posted on Feb 01, 2009
How do i get the start button on my desktop
sorry but my deck tops do not have icons they have physical buttons on the bax to start them .
Oct 22, 2015 | HP Computers & Internet
No desktop icon,no taskbar
Sounds like explorer.exe has crashed. Press CTRL-ALT-DELETE once. This will bring up the Task Manager. Click on 'File', then 'New Task'. Type in 'EXPLORER and click 'OK'.
This should start up a working copy of Explorer.exe and you should have your taskbar and desktop back.
Aug 09, 2011 | Microsoft Computers & Internet
I have lost ALL of my taskbars!! How do I get them back?
A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
  1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
  2. On the Applications tab, click New Task at the bottom right of the window.
  3. Type explorer.exe, then click OK.
If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
If that doesn't work, then try this:
  2. Go to the Processes tab.
  3. Click on the Image Name column header to sort the list alphabetically.
  4. Find all explorer.exe processes - select each, then click End Process for each one.
  5. On the Applications tab, click New Task at the bottom right of the window.
  6. Type explorer.exe, then click OK.
Are you using snagit, try to uninstall it and then check if you still get the errors. If you donot use snagit then there would be another error.
If you cant access control panel use the "Windows Key+R" on the keyboard which opens the run dialog and type in 'sysdm.cpl' which opens the control panel.
You could also try to restore you windows using System Restore and select a date of the backup when the computer was working well.
Make sure you do a complete virus scan with a good antivirus with updated virus definitions as it could be a virus too.
Jan 21, 2011 | Computers & Internet
I reduced the volume of my laptop.the next day i turned on my laptop and i could not find the icon volume in my system tray.it desappear and the volume box is gray .how can activated.thanks
Hi micochereami,
You can fix this issue by restarting the "explorer.exe" services. To restart the explorer.exe service, please perform the steps given below.
  1. Right click on the Taskbar and click the "Task Manager" to open it. (You can also press "Alt+Ctrl+Del" or "Ctrl+Shift+Esc" to open the Task Manager.)
  2. In the Task Manager window, please click the "Process" tab.
  3. In the Process tab, locate the "explorer.exe" process.
  4. Once you have located the "explorer.exe" process, please right click and select the "End Process" option.
  5. Then, please click the "File" option in the Task Manager window and select the "New task (Run..)" option.
  6. Then, in the Create New Task window, please type "explorer.exe" and press the Enter Key.
  7. This should fix the issue.
Good Luck!
Please post if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 08, 2010 | Sony VAIO VGN-CS215J/W Notebook
The taskbar disppears. I have it locked so that it should always be on top of everything else but when it goes into hibernation and it restarted it disappears.
I'm had the same problem with my system. if the 'Start' button is still visible, so you can right-click that, select 'Properties' and change the TaskBar settings.select the 'Autohide the Taskbar' and applying that change will result in the Taskbar appearing again (at least when the mouse pointer is positioned by the Taskbar).
if the above one does not work a simple solution that will work:
1. Hit CTRL+ESC to show the Start menu.
2. Right click the menu at the bottom for Properties.
3. Select the Taskbar tab.
4. Check Autohide Taskbar and click the apply button.
5. Uncheck Autohide Taskbar and click the apply button once more.
Your taskbar should reappear when you've completed these 5 steps.
Please give this a try before messing with registry or recovering your machine!
If the taskbar does not show up when you press CTRL+ESC then explorer.exe may not be running. To correct this press CTRL+SHIFT+ESC which will bring up the task manager. Click File, New. Find explorer.exe and open it.
Go into Task Manager. Find explorer.exe and end the process. Restart explorer.exe. If your taskbar magically reappears, you've found the issue. Here are some other symptoms:
After a Windows Vista-based computer has been running for an extended period of time, the desktop screen may stop updating correctly. For example, you may experience any of the following symptoms: • Parts of the screen may go black. • Parts of the screen may become transparent. • The toolbar may disappear. • The toolbar may appear at the top of the screen instead of at the bottom of the screen.
If you add the GDI Objects column for the Explorer.exe process in the Task Manager console, you see that the GDI Objects column has reached the maximal number that is defined in the GDIProcessHandleQuota registry entry.
A hotfix is available from Microsoft: http://support.microsoft.com/kb/932406
Jan 07, 2010 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
My desktop Taskbar is gone!
Bring up the task manager. Click [File] then "New Task(Run)". Type "cmd" into the text field and press Enter. This will open the command prompt.
Dec 08, 2009 | Computers & Internet
My desktop keeps disappearing
Hi!
Remove unnecessary programs installed on your computer. This will help you save space and then more room for special processes for system performance.
Next, I advise you to run a full computer scan. This will help eliminate viruses or spywares on your PC and I think which is also the culprit to your Desktop suddenly dissapearing. Viruses are nasty and they will do everything to bug your computer down.
Sep 10, 2009 | Computers & Internet
Icons and Start tool bar disappearing every few seconds
Sounds like the explorer.exe process might be restarting. Open Task manager and keep refreshing the processes to see if explorer.exe disappears/re-appears.
Jan 29, 2009 | Dell Inspiron 1501 Notebook
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Start Menu and Desktop Icons...
Is it a valid version of Windows? If not the Authentic Windows validation update might have disabled normal function of the OS. Otherwise this may be serious damage due to spyware. Spyware software like SPYWAREDETECTOR are about $30 per year and work pretty well. Free ones are often 'get what you pay for' quality - crap. You may also have to use the windows disc to run a repair to fix the damage done once the spyware is gone. Or reinstall Windows.
Sep 13, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
314 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
