Question about NetGear WGR614 Wireless Router
My neighor stealing my signal
I'm passing for my service and my neighbors are using
my signal for free. Help!
I need the security code.
  • 219 Answers
You need to encrypt your wireless signal. Here are some instructions for getting in to your router's control panel.
Once you manage to log in, find the firewall region or wireless security region. Make sure to encrypt your wireless connection with the WPA-PSK authentication method using the TKIP encryption. Make sure to write down your pass-phrase, as you will need it to connect to your wireless connection.
Posted on Jan 31, 2009
How do I prevent my neighbor from using my wireless router?
If you do not have any wireless network security enabled on the router, your neighbor can see this SSID and connect to the network without authorization. While this is generally frowned upon as being unethical, it is technically not illegal as you have "made the network available" by failing to secure it. The easiest way to secure the network is through the use of a WEP key or a WPA pass-phrase. WEP keys are generally 5, 10, 13 or 26 randomly generated characters long. WPA pass-phrases are just that - a phrase such as "The sun is yellow". Either method will prevent unauthorized users from accessing your network. Only those individuals who possess the key or pass-phrase are granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Jan 22, 2013 | Belkin Computers & Internet
Neighbors I'm insulted
Do you mean your neighbours are using your wi-fi signal for free.
If they are then you need to secure you network.
You need to go in to your router's settings and create a wep key or wpa key in the Wireless security section that only you will know.
Feb 02, 2012 | Computers & Internet
How can I be sure my linksys security is up to date without the original disc that came with the router? I am trying to be sure that my linksys is not an open gateway for neighbors to steal access from...
If you want to make sure that the signal from your router is secured, the only way you need to do about that is to put in a password or passphrase before connecting to the wireless connection. that is the security the router can give you. unless they know the code. they wont be able to connect to your router freely. and about the updates on the linksys, it is ok not to update at this point. and even if you dont have your disc. the router will still work. the disc only give you a software for the router to connect automatically. while windows can already give you that option.
Hope this helps. thank you for using Fixya,
Jun 11, 2011 | Linksys Wireless-G WRT54G Router
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do i block someone from illegally stealing my wireless intern
You have two options to stop someone from stealing your wireles connection.
The first is to use a more secure encryption.
Use WPA2 personnal with AES encryption.
You can set this security mode by logging on to your router and changinhg the wireless security.
The next solution is to turn on MAC filtering and make sure her computer is not listed as a safe MAC address.
This is also turned on from the router.
Hope this helps.
Apr 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Neighbors stealing internet access
It's no problem all you need to do is access the administration page of the wireless router and setup security. Depending on what type of device you have there are several options. The most basic security is fine and you will need to create a passcode so that the PC's you want to access then internet will work. Then when security is setup you type the access codes in your PCs and you are good to go. I know this is very generic but I don't know which router you have. I can be more specific if you need, just let me know. Usually you access the admin page by the IP address of the router entered in Internet browser then it will ask for user and pass. ( if I know the model I might be able to tell you that as well)
Hope this starts the process for you, just send me comments if you need specifics
Apr 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Neighbors can use our connection to log on to laptop
Consult your users manual for setting up either MAC Address Filtering, which will allow you to enter the physical addresses of your devices (unique like a fingerprint.)
Enabling Wireless Encryption (Wireless Security), which would require you to enter a pass code or pass phrase in order to access your networks assets.
Please let us know if you need any further assistance. If this information was helpful, please take a moment to rate the solution. Thank you.
Apr 22, 2009 | Computers & Internet
Lost cecurity code
Yesterday after searched around, finally i found a site contains codes for all type Nokia phones, such as: latest firmware, unlock, security code, hidden secret, and more.
If you need, can find them here:
For all Type Mobile Phone here :
Or check this also
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Jan 05, 2009 | Nokia 1600 Cellular Phone
My neighbor is using the signal from my modem. is there a solution to this?
Two (2) ways:
1. Use WEP or WPA security key (but that has been known to cause a slowdown);
2. Use MAC filtering which will restrict devices whose MAC numbers are entered into a table of allowed PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 21, 2008 | Computers & Internet
NetGear WGR614 Wireless Router Logo
143 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
