Question about Whirlpool Duet GHW9150P Front Load Washer
My control lock is on and my machine will not turn on.
It worked yesterday. This morning I went to do a load and the control locked button is on. It will not let me change control or start the machine.
  • 2 more comments
  • cofi4 Feb 01, 2009
    did you ever get it fixed? Mine is doing the same thing?
  • hefners5 Feb 01, 2009
    Same thing here.
  • gsm617 Feb 01, 2009
    control lock is lit -- how do i start machine and unlock control?
  • dburt3891 Feb 01, 2009
    The contol lock is on. If while holding the control button I push and release the cancel button, the display will show 00 time left. Pressing the control button returns to initial problem: the control locked light is on.
    President:
  • 1,294 Answers
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
Posted on Mar 26, 2009
When i turn it on loc comes on and i cant get it to work. i tried yesterday and it said pause then error
The control is locked as what "LOC" indicates. Press the Options and Select buttons simultaneously for 10 seconds or until "LOC" is no longer displayed. Pressing the same buttons for 10 seconds will lock the control. There is actually a padlock sign marking between these buttons to indicate that these buttons are used for locking and unlocking the control.
Sep 04, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Controls locked
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
To fix the control lock you hold down the control
Holding down the control lock button for 30 seconds did NOT work for me.
I went straight to Whirlpool.com and found that if you Hold down the
END OF CYCLE button for 3 seconds, the control lock turns off and the
washing machine is again operable
Oct 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I press buttons to turn dryer says lock and
press and hold the select and cancel buttons for six seconds this should reset the dryer control.also try to unplug the unit for a few mintes
Sep 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Sears HE4t Control Panel Locked
press/hold the lock button.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
The control lock light is on
there is a button on the far rt of the face of the machine...you hold that button down. the button is called end of cycle signal.
ann
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control lock
Try pressing and holding the "End of Cycle Signal" button at the bottom right corner of the control panel. This works for me!
Mar 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3t Front Loading Washer
Try holding 'end of cycle' button for 3 seconds. If not........
  • Door Lock Mechanism broken or removed from the door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If you get the door to open try some WD40 on the door mechanism, not on door, and open/close a few times. "Plug should be off the wall" when trying this, and tinkering inside machine, caution.
Feb 05, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
