Question about Zanussi IZ12 Front Load Washer
Zanussi IZ12 Pumps, then Pause LED is flashing.
Zanussi IZ12 washing-machine Pumps, then Pause LED is flashing. Machine NON operational then. Removing the Powercord for 15 min. lets the machine work for a few minutes.
  • 2 more comments
  • Arjen Hager Aug 03, 2007
    Sorry for sounding "Unpolite" that was not my intention. The solution however was not a very plausible one...
    Strange enough the machine has done 5 cycles without any problem the last 2 days. I expect the problem will return within some time, but for the moment it works. All filters were cleaned already, incoming water valve also worked OK when the problem was there.
    Thanks for your reaction, and I hope the mysterios problem will keep away for a long time !
  • Madam skyler Dec 22, 2008
    filled the machine, set temp and spin and hit start but the light still keeps flashing, all buttons still beep, i've emptied all filters and checked drains and so on, but its still not working it is currently unplugged for the 2nd time, what else can i do?!
  • Anonymous Mar 12, 2014
    our make is zanussi jetsysstem iz12
  • Anonymous Mar 27, 2014
    Led lights 2 4 and 8 flash
Hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Posted on Jul 11, 2008
  • 641 Answers
Remove the power cable for few hours and then try again. Good luck!
Posted on Jul 31, 2007
  • Dov Dror Aug 03, 2007
    Following your "polite" react, I understood that my first try to help you didn't work.
    It sound like your problem is with the incoming water line.
    - Check for clean filters.
    - Check incoming water valve.
    If the problem will return (and I really hope that this mysterios problem will keep away for ever !!) look for a loose wire connection.
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
Zanussi washer iz 12 error e10
Switch off.
Press and hold the two buttons again and switch on.
The appliance will beep or flash, let go of the buttons, the leds will scroll.
Press and release the temperature button until the bottom led of the 2nd column is lit.
Let me have the error code.
Switch off, on and off again
Nov 28, 2010 | Zanussi IZ12 Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Error e51 on zanussi iz12
Dec 07, 2009 | Zanussi IZ12 Front Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Drain pump for washing machine
the pumps vary a lot but if in the uk, pump cost is about £25 and fitting about £40 but why do you need a pump?
Oct 22, 2008 | Zanussi IZ12 Front Load Washer
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
529 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
