Question about Intel FC-PGA2 Tualatin Adapter for Socket 370 FC-PGA Motherboard CPU Cooling Kit
List of cpu support for pga 370 motherbord
I wanna know what all processors can a 810e Micro-ATX (pga- 370 socket) can sopport
    Problem Solver:
  • 12 Answers
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Posted on Feb 03, 2009
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
Sep 26, 2010 | ASUS Intel 810E Chipset CUWE-RM...
Hi dear can this motherboard suport intel pIII
Here are the specs. to this motherboard Product Details Intel 810E Chipset, Socket 370, Compatible Processors: Intel Pentium III Specifications Key Features Chipset Intel 810E Compatible Processors Intel Pentium III Processor Max supported CPUs qty 1 Socket Type Socket 370 Memory Number of Memory Slots 2 x DIMMs Audio / Video Video Out Ports 15 Pin D-Sub VGA port x 1 Other Features Package Qty 1 Chassis Type Desktopso to your queston... Yes it supports Intel PIII have fun >.<
Feb 25, 2010 | Dell (002TR) Motherboard
Looking to build using hp 5716 case. need to know where to find out what mb will fit case.
The size of a motherboard, is the Motherboard Form Factor.
I'm willing to bet the Presario 5716 uses the Micro-ATX form factor, but could be wrong, and it could be the ATX form factor.
I base this belief on the factor, that I think the Presario 5716 uses a Mid Tower size of computer case.
The motherboard Micro-ATX form factor size, is 9.6 inches by 9.6 inches.
(9.6 inches is about 9 and 5/8th's inches.
5/8th's of an inch = .625)
Metric conversion for the above is 244mm by 244mm)
The ATX form factor size is 9.6 inches by 12 inches. (244mm by 305mm)
Inside the computer case is a Support Plate. The Support Plate, is what the motherboard screws down to.
Sometimes it's a separate piece, but for the Presario 5716 it's probably riveted to the case.
Looking at the Support Plate, you may notice the abbreviations mATX, and ATX by the motherboard mounting holes on the Support Plate.
mATX standing for Micro-ATX, and ATX standing for the ATX motherboard size.
This will be more readily spotted with the motherboard removed.
If so you can use either form factor of motherboard. You may Not be able to reuse the I/O plate, (I/O Shield), at the rear of the computer case. (Input/Output shield - plate)
The shiny rectangular, thin piece of metal, that covers the I/O ports. (Examples: Mouse, Keyboard, and Monitor to name a few I/O ports)
This rectangular plate pops out with a BIT of persuasion. The new motherboard should come with it's own matching I/O Shield.
WARNING!
The inside edges of the computer case, where the I/O Shield is mounted, are SHARP!! Use extreme caution, and perhaps gloves to remove the I/O Shield.
Once the old I/O Shield is removed, it is readily apparent of how to install the new one, and could avoid possible confusion of me trying to explain here.
Sometimes the I/O Shield that comes with the new motherboard is not a direct replacement, as to fitting in the existing rectangular hole, in the computer case.
In this instance, a little modification is in order to the computer case.
(IF so, remember to smooth the edges with a file)
This link to Wikipedia explains the motherboard form factor pretty well, and also has photos, and charts,
http://en.wikipedia.org/wiki/Motherboard_form_factor
(You can click on any photo to enlarge it. There is a chart at the bottom of the page)
Now you know,
A) Motherboard Form Factor
You can measure the old motherboard for it's size, and know what form factor it is.
B) Support Plate, and the mATX, and ATX designations that may be stamped, or printed near the motherboard mounting holes, on the Support Plate.
If the old motherboard is not obtainable, you can look for the above designations, to see what motherboard form factors apply.
You can also use a tape measure, and measure the distance in-between the mounting holes, and obtain a rough guess.
It won't be that rough a guess, when differentiating between 9.6 inches, and 12 inches.
C) When looking at a website that sells motherboards, you can look in the specifications description, and look for the designation ATX, or MATX, to see if that particular motherboard will fit in your Presario 5716 computer case.
(mATX, and MATX = Micro-ATX)
As for buying a motherboard that will equal the specifications of your old motherboard, good luck.
You can buy an exceedingly cheap motherboard now, that will outperform your old one, like a dragster flying by a snail, in comparison.
You won't be able to reuse the old Processor, and is doubtful that you can reuse the Ram Memory.
The Ram Memory, is SDR Sdram, that operates at a frequency rate of 100MHz FSB. (PC100)
(Single Data Rate Sdram is commonly just referred to as Sdram. Speed is slang for Frequency Rate)
The Processor, is either an Intel Pentium III that fits in a Slot 1 processor socket, or the Pentium III type that fits in a Socket 370 processors socket.
The Pentium III processor, that fits in a Slot 1 processor socket, is about 5-1/4 inches long, and 3 inches tall. It should have a black plastic case around it. Thickness is around 3/4th's of an inch.
The Pentium III processor that fits in a Socket 370 processor socket, is about 1-1/2 inches by 1-1/2 inches, and is square.
The Pentium III processor used in the Compaq Presario 5716 operates at a maximum frequency rate of 450MHz. (MegaHertz)
This gives you an indication, of what a Pentium III Slot 1 processor looks like,
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%20450%20-%2080525PY450512%20%28BX80525U450512%20-%20BX80525U450512E%29.html
Feb 02, 2010 | Compaq Presario 5716 PC Desktop
My computer wont power up until i try it at least 20 times. it has a celeron processor. do i need a new processor? or what? i would rather repair it myself.
First open cpu cabinet.
Reattach ATX power connector from smps to motherbord.
Refix RAM memory.
Pull cmos cell from motherbord for 10 minutes.So all settings are defaults.
Pull processor fan and processor then refix both Clean dust from all parts.
Remove pci cards from motherbord.
Make sure motherboard is not ground with cabinet cover.
Then check.
TRy with another RAM .
If still same problem then you need top change your motherboard orm processor.
Let me know if you need further assistance.Thanks for using FixYa.
Nov 25, 2009 | Sony Computers & Internet
I HAVE A SOCKET 370 MOTHERBOARD WHAT IS THE DIFFERENCE AND THE FCPGA VS FCPGA2? AND HOW DO YOU KNOW WITCH TYPE WILL WORK ON THE MOTHERBOARD THANKS COOL KID
Intel Pentium III and Celeron CPUs less than 1001 Mhz were FC-PGA.
Intel Pentium III and Celeron CPUs more than 1200 Mhz were FC-PGA-2.
However, Intel made CPUs in the 1000 to 1200 range that were FC-PGA
*AND* Intel made CPUs in the 1000 to 1200 range that were FC-PGA2.
So, all FC-PGA CPUs will work in almost every Socket 370 motherboard,
but all FC-PGA-2 CPUs require a motherboard that supports FC-PGA-2 CPUs.
Nov 18, 2009 | Computers & Internet
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Help me please..I can not see anything in my computer screen after I turned my cpu off due to the monitor display got flickr. My Mobo is asus p5gcmx and since one year ago it processor has been overclocked...
ok
open cpu covers and check on motherbord u find cmos cell on it
It is round cell on motherbord
pull away it from motherbord for 15 minutes then refix it again then it reset to factory defaults.
Apr 16, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Intel FC-PGA2 Tualatin Adapter for Socket 370 FC-PGA Motherboard CPU Cooling Kit Logo
726 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
