Question about Kodak EasyShare C763 Digital Camera
The flash won't turn on
I can't figure out how to get the light off when i take the picture
What kind of flash ? SB800 ?Sb600 ?
or are you using compact..if you're using compact,I guess you'll be needing Manual mode and tweek something on the setting menu.
Posted on Jan 31, 2009
Canon pc1251 won't take picture with flash on. it will if i turn off flash
Check if your camera is on automatic. Then f there is too much light it won't work. To use a flash for fill in, you have to be on a scene mode. Check the manual. If the camera has a flashing light, indicating the flash won't work, you have a serious problem.
Dec 10, 2014 | Canon Cameras
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture...
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Dec 04, 2013 | Cameras
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Picture white
it could be from the erratic flash of light, against the sun, you can try focusing.
also turn the flash to auto mode.
dont forget to rate this pls
Aug 30, 2008 | Argus QuickClix 5150 Digital Camera
Kodak EasyShare C763 Digital Camera Logo
77 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
