Question about Kenmore 82822 Electric Dryer
The door handle on the dryer broke,
Do I need to remove the back of the door to gain access to the screw that holds the handle. Looking at the part drawing, it looks like i have to, I just want to be sure. Model number 110.92824101
Thanks for the help.
    Problem Solver:
  • 18 Answers
Yes you will need to open the door and remove the screws around the inside of the door and then the outer skin will pull off and you can access the door handle screws
Posted on Jan 31, 2009
Replacing door handle on a 2005 Mitsubishi Endeavor XLS rear passenger door handle
Remove inner door handle and arm rest if applicable, with a flat screw driver or chisel leaver door cover away so as to gain access, undo the screws on old handle,remove rods ,then remove handle fit ,new handle .mark rods with paint so they go back in the same place.
Apr 24, 2017 | Mitsubishi Cars & Trucks
How do we replace the shattered inner glass of the oven?
Most oven will have a series of screws that hold the door halves together and you would need remove those so that you can gain access to the glass panel. Some doors only have two screws that also hold the door handle on and you would have to remove just those to gain the access you need. Hope this helps!
Aug 11, 2015 | Combi Ovens
GE JVM1660AB002 Microwave door handle broke at the bottom. I removed part of the inner plastic door panel, but can't get the panel removed from the main door at the side where the hinges are attached....
Hello & Welcome to FixYa
Please review this video if you want to replace it yourself:
Please get back to me if you have any other questions.
Jul 14, 2011 | GE JVM1660 Microwave Oven
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
Jul 03, 2010 | KitchenAid KBMS1454RSS Microwave Oven
1995 Beretta: The passenger side door handle broke while opening...
it is an easy fix! there are 4 screws needing to come off the door to gain access to the interior. once in you will need to release a clip and also remove a bar from either an orange or black clip....once these are removed, you put in the new door handle, attach the clips back on, attach the screws and you are ready to go!
May 18, 2010 | 1995 Chevrolet Beretta
Maytag dryer , drum not turning , belt broke
remove the two brackets on the back holding the top cver to the rear back cover. One screw is on each bracket. Next pry the top covers front section. It has hold down springs keeping it on. They snap right off. Now remover the front outer panel to gain access to the drum. You will need a new tensioner pulley and a belt to fix your dryer. The inner roller bearing is dried up and a replacement is needed with a new belt as well
Apr 21, 2010 | Dryers
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
How do I replace the interior LH door handle 97 Jeep Wrangler?
you will need a t-20 or t-15 torx bit driver to remove 2 screws holding the handle this is all that holds them on, on once you have a replacement handle it is easier to remove 2 lower screws on the door panel and unsnap the door panel to loosen it this will allow space making it easier to reinstall new handle just slide each end into the slot and reinsert 2 screws to not fully tighten until door panel is snapped back in. the panel is held on with clips and can be released using plastic pry tool around door panel edges.
Nov 22, 2008 | 1991 Jeep Wrangler
My driver's side window will now roll up how do I fix it?
most likely the window regulator has broken inside the door and will need to be replaced as well as the regulator handle. To remove them you will need a basic metric socket set, screwdrivers, and a rag or shop towel. start by moving the rag back and forth behind the window crank in order to remove the retaining clip. then once removed pull the crank from the splines of the window undo the screw in the door handle press forward on the handle to release it from the door then undo the lock rod clip and remove the handle. there should be two large phillips head screws below the arm rest remove these. gently slide a flat bladed screwdriver under the bottom edge of the door panel. prying up to remove the retaining clips used to fasten the panel to the door. if you break the clips you can get replacements at most auto parts stores in their help section. Next lift the door panel up while lifting the bottom edge away from the door to remove the door panel. once inside the door you will need to lift the window up to gain access to the two 10 mm bolts attaching the regulator to the glass. undo the regulator retaining bracket and retaining bolts from the door. remove the regulator an assistant can be helpful to hold the glass up while you remove the regulator. installation is the reverse of removal
Sep 13, 2008 | 1994 Geo Prizm
Kenmore 82822 Electric Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
