Question about HP D8597A Keyboard
Loose Key My A key is loose and I dont know how to reinsert it. How can I get it back into the keypad?
  • chanisalsa Jan 31, 2009
    O NO! It's not broken. It just came unclipped
    I took it to the Geek Squad and they were able to just snap the key back into it's origional place. As I mentioned it was just loose, not broken; No Super Glue just snapped back into place.
  • 741 Answers
This happened to me recently. If you can't snap it back on then it means it has broken off clean. What I did was get some super glue and put a small amount on the bottom the key and a little on the keyboard and glued it back on. The only other option is to buy a new keyboard, you can find them pretty cheap on the web.
Don't foget to rate this solution with 4 stars.
Posted on Jan 31, 2009
  • Randall  Trahan
    Randall Trahan Feb 01, 2009
    Glad to hear things worked out ok...
    Sergeant:
    Champion:
  • 289 Answers
Just apply quickfix and paste it..thank u
  • Hariharanath V Jan 31, 2009
    oh then u just press it hard
How do i disassemble the DirecTV RC71 Remote?
Check for more screw(s) behind the label/sticker. Also, you may need to have a flat edge screwdriver or knife to prise open the remote.
Sep 24, 2014 | Directv Televison & Video
How do you fix the keypad? I cannot type anything
Sounds like the main lead of the keyboard has come loose, either that or the key board needs to be replaced. Here is the link to the video instructions on how to replace, I would follow the instructions on the removal and check the main power cable of the key board and make sure it is not loose before you buy another key board, cost for a new key board should range from 8 to 15 dollars. http://www.youtube.com/watch?v=1vRglqfQjyE Hope this helps. :)
Sep 04, 2011 | ASUS Eee PC 1000H Laptop
Phone memory low delete some data i cleared all privacy and cookies and catch all messages i dont have no games on my phone memory no apps are running there is alot of mdip on my phone memory but dont know...
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 08, 2011 | Nokia E71 Smartphone
Display is not working on my nokia 6600 phone.When i switched on my phone a white displat appear for a sec and then switched off automatically. I dont want to format my phone because there are many...
hey friend if you dont want to loose your contacts , then you can do one thing thet you cant make soft format to your cell phone..
  1. Turn your device off.
  2. 2Remove SIM card and MMC card (actually, you do not need to remove these, but after format remember to format memory card and reboot phone).
  3. 3Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad Together.
  4. 4Turn your device on while you are pressing the three buttons.
  5. 5You should now see "Formatting .." on the Screen! Leave the buttons now.
Dec 14, 2010 | Nokia 6600
Buttons wont respond when first turn on
One of 3 things may have occur 1st loose connection between keypad to upper electronics, 2 nd Defective keypad , last but not least the upper electronics. If you are able to disassemble the upper console inspect and look if any connections that are loose , physically pull and replace connectors one at a time, then test your unit to see if key function return. Proceed to next step is replacement of keypad, if not it then it is the upper electronics.
Apr 25, 2010 | Precor EFX 546i Elliptical Version 4
Buttons not working
The volume key is stuck that's why the volume bar keeps on popping out. It is also the reason why the keypad is not working. You have to unstuck the volume key to check if the keypad really doesn't work.
  1. Remove the battery cover and battery.
  2. Remove the camera cover by prying the locks along its sides and lifting it up to expose the volume keys.
  3. Insert a needle between the volume key membranes and the board to unstuck it. The membranes should click when pressed.
  4. Install the camera cover in reverse order.
Inform me if the volume keys work fine but the keypad buttons don't.
Jan 01, 2010 | Nokia 5310 Cellular Phone
Keypad in w350i not working...how 2 repair tat
Remove the external key pad and press the internal keypad on the phone board directly, may be the external key pad rubber is not contacting the one on the phone board.
Or you can loose the phone, and clean the internal part of the key pad. There might be dust on it, you could also use this medium to service your phone. If it does not work after all these, then I think you have to change the key pad completely.
I wish you the best.
Nov 23, 2009 | Computers & Internet
Key on keyboard came loose
This is issue with laptops when you type fast sometime you hit the keys from the side and overtime they come loose or from overheating…the only way is by replacing the keypad…sorry.
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | HP Compaq Presario CQ50-140US NoteBook
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Letter key on our keyboard doesn't work when you type on it
if handy with tools you can open KB an check all traces are good
if not need to use a HB pencil to re-trace grid @ non-working key
May 08, 2009 | Computers & Internet
HP D8597A Keyboard Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
