Question about NEC MultiSync LCD1830 18.1" LCD Monitor
Black screen First NEC 18.3 quit just before my "2 year" warranty expired.(Not 3 years) Was replaced and now just under or around the 3rd year mark it also went black. A local "expert" tells me that the back light doesn't function as he can see a silhouette in the background. I paid over $1000 at the time and nobody wants to give me a repair cost. Since the drastic price drop on good quality monitors nowadays is it worth the repair? Thanx Jake
  • NEC Master
  • 12,061 Answers
If ya can get the parts easily then it's NOT too hard to replace the "Back light" there isn't too much inside these monitors, generally there are 3 main parts the LCD and it's electronics, a Video interface for Monitor - PC,and the Power Supply Unit, (PSU). I have found that a VERY high percentage of problems with Monitors like this are in the PSU, and generally it is faulty, Electrolytic Capacitors... Personally unless it was an "Easy Fix" I would opt for another unit with a 3 year warrenty...
Posted on Jul 30, 2007
SOURCE:
I have a Bunn BTX-B. It just stopped heating the water. I received it as a Christmas gift, purchased on Dec. 24, 2010, from Lowes. I do not have the receipt. I emailed customer service. They sent me two...
Warranty is 1 year parts and labor, 2 years parts only and 3 years for control boards. That model does not have a control board. You could have a bad thermostat, bad high limit, bad thermal link or bad element. Without you having a multimeter anSd the knowledge of how to use it properly it would be best to replace the unit.
Dec 27, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Tip
How to end Compaq CQ70 misery
I have owned a CQ70 for 2 years 2 months. Before I reveal my tips, here's my experience:
On purchase:
- quick start guide doesn't even show keys and switches, how to use camera, etc
- no software or manual supplied, only useless safety guide CD
- request for info to Compaq online: they returned a form to let them know how well they had served me when they hadn't served me at all
- subsequent requests unanswered
- complaint to www2.hp.com returned a worm called HTML-script-inf
First year:
- keyboard failed after 2 months; replaced under warranty
- screen failed after just under a year; replaced under warranty
- sound regularly disappears; have to reboot
- carrying bag burst within 6 months
- SD card reader worked intermittently for a few months, then not at all
Second year:
- I accidentally discovered the touchpad disable button; it doesn't work
- battery expired after 18 months
- replacement screen started to fail after 18 months
Now:
- replacement screen failed completely after 2 years 2 months
- I get electric shocks off the left side
- it generates constant flow of "Enter" commands; keyboard, mouse, USB ports cleaned to no avail; clears on reboot for a few hours (no viruses / worms - I regularly check)
- the HDD will not start spinning on mains power; I have to remove power cord and start on battery only, then replace power cord
Tip #1: I understand from a friend who works for HP that the good components go into the HP series and all the s*** into the Compaq series, so DON'T BUY COMPAQ.
Tip #2: If you have already bought one, put it in the bin or use it for landfill
Tip #3: If you want a reliable computer that will last for years, buy a cheap and cheerful Taiwanese no-brand. We've got two - they're great.
on Jul 05, 2011 | HP Compaq Presario CQ70-120US Laptop
T.v. will not come on model LT 2327
This is either a power supply problem, or, as I suspect, the capacitors are blown out on yuour screen. Alot of screens nowdays are having this problem, as they come with capacitors to energize the screen, and the capacitors are coming from China and Taiwan, with low quality standards. The caps should last between 15-20 years before going out, but on alot of these tv's the caps are burning out in about 18 months to 2 years. If your tv is still under warranty follow the warranty instructions for repair, if it has no warranty, or if it has expired, then take it to BestBuy or Fry's electronics. They both have special technicians for this type of service. Just Know that it is not cheap, as the repairs can sometimes cpst as much or more than the cost of a new TV.
Dec 17, 2010 | Norcent Technologies LT-2723 Television
3 red lights ive had the xbox 360 for 18 months now will it stil be under warranty did not take the extra cover out only got 1 year with it but ive heard that microsoft are guarrenteed for 3 years with...
you can fix it yourself but you need to know what your doing altho it is actually quite easy to do, but yes u are correct if your console has 3 red flashing lights the warranty is 3 years but only for that error, so your in luck send it back to Microsoft and they will ship a new one to u, usually takes around a week
Nov 06, 2009 | Microsoft Xbox 360 Console
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
Officejet Pro L7590 printhead message (printheads only 2m. old)!
Pull out the printhead from the computer and check the date under "warranty ends" If the warranty period did not lapse, call HP technical support and tell them about the problem. They will replace the printhead for free. I have gone through 3 black/yellow printheads and I received the replacement printheads via FedEx within 1-2 days. They will send you a pre-paid envelope to return via U.S. Postal Service via US Postal Service.
If the Warranty date on the printhead expired, then you may have to come out of pocket to replace the printhead since HP will argue that they are not obligated to replace the printhead since the manufacturer warranty lapsed.
If this is the case, check to see when you purchased the printer. If the purchase was within a year, the retailer (i.e. Best Buy) is on the hook since there is a 1 year implied warranty on products such as printers, regardless of whether the expiration date on the HP printhead expired.
Hope this helps
Aug 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Guranteeofasustekmotherboard
http://support.asus.com/service/service.aspx?no=231&SLanguage=en-us
Motherboard 3 Year Since 2000/1/1 onwards Notebook 2 Year Since 2002/2/1 onwards Portable PC (Degatto PC) 1 Year VGA Card 3 Year Since 2001/1/1 onwards (3 year warranty)
Prior to 2001/1/1 (1 year warranty) CD /DVD /CD-RW /DVD-RW Drive 1 Year Server 3 Year 3 year warranty coverage on ASUS' full system. Applicable only to components with genuine ASUS label sticker installed on ASUS Server. Warranty period is determined by the serial number on ASUS Server. Wireless Products 2 Year PDA 2 Year Since 2003/2/18 onwards
Dec 27, 2008 | Computers & Internet
LCD Philips 26pf8946 after about 45mins right hand 1/3rd picture not viewable
Hi Darnez,
It sound like to me that one of the boards that power the bad side of the screen is getting hot and quitting. The boards are not too expensive to replace but getting them is generally the big problem. ( At least for our company). The set would be worth tkaing to a local shop and have it looked at, but replacement costs are going down every day it seems.
Good Luck
I hope in some way this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 27, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
NEC MultiSync LCD1830 18.1" LCD Monitor Logo
308 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
