Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Installing to the mains water supply
No manual supplied, need to know what to use to install to water mains
    Problem Solver:
  • 10 Answers
If you want to connect to an icemaker, youll need about a 1/4" plastic line,could be bigger or smaller, depending on model.. then you need a saddle valve to connect to cold water line. Go to home depot or your local hardware and they can help.
Posted on Jan 31, 2009
How To Replace Outside Tap Washer in Australia
To replace outside tap washer follow these instructions below or folow this link to watch video. http://youtu.be/xjjYSZPBaGo
Turn off your main water supply before you start.
Turn tap to on position.
Remove spindle.
Remove worn washer.
Install new washer.
Reinstall spindle.
Turn tap to the off position.
Turn your mains water supply back on
Jul 06, 2012 | Cars & Trucks
Need to know how can I monitor water level into municipal supply water pipes and install sensors/flow meter so as to automate start/stop water pump
http://uk.rs-online.com/web/generalDisplay.html?id=services&file=cc
they have them in reception
Apr 13, 2012 | Garden
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Installation
Hi
Please follow LG instrcutions for installation of your dishwasher, check the Installation manual--
LG Dishwasher Installation Manual
· You should have at least four feet of wire free at the end of the line where the dishwasher will be installed.
· Prepare the water connections. Use a proper compression fitting water supply hose.
· Remove any protective shipping packaging or screws.
· Cover any exposed wires with electrical tape.
· Check the water supply and drain hose for any leaks.
Hope this helps...
Daniel
Aug 14, 2010 | LG 24" Built-In Dishwasher - Black
How to connect radiators to the pipes
I am assuming that the radiators you want to hook up are designed for hot water? If so you will need to run two pipes to each radiator, one for supply water one for return. Radiators work well on a monoflow Tee installation ( I suggest you Google monoflow tee intstallation). Valve the supply side so you have some adjustment of water flow to regulate the amount of heat it will put out. From your boiler you will need to install a main supply pipe all the way around the perimeter of the house (in the basement). I suggest a 1" diameter copper pipe. Then you will need to locate your radiators. Install a supply tee in the 1" pipe and go up to your radiator with either 1/2" or 3/4" copper pipe. Install a valve in this line to regulate flow. Connect to the radiator using the correct fitting. On the return side, connect to the same diameter pipe as the supply and take that down to a monoflow tee installed in the 1" copper pipe. Make sure you face the tee correctly or you will not get flow thru the radiator. Because there are different methods to connect radiators, this is just a suggestion. Google the net for other suggestions, talk to a heating professional and study prior to installing or it will cost you money and aggravation.
Nov 05, 2009 | Heating & Cooling
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
I have installed an AS 2555.501 Pressure Balance Vave and now the water pressure in the shower is low
this problem happens quite regularly as the valve will reduce the pressure but sometimes it will reduce too much, you can adjust it up, but you havent mentioned which type of shower valve it serves?
as the shower may not be suitable for the plumbing supplies it connects too , & how they are installed?
i am thinking its from the cold water main & that the valve requires storage feed instead of incoming water main supply? possibly thats why you installed a reducing valve??
Let me know?
Kindly
Richie
Dec 15, 2008 | American Standard 2555.501.295 Satin Town...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
80 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
