Question about Goldstar R5050 Air Conditioner
Installing Lost Manual. Do not know which way the curtains on the side go when installing in a window. Which way do they face
  • 50 Answers
Turn the curtain and bracket so when mounted to the ac the window will close behind it. Hope this helps. Thx RepairUSA
Posted on Aug 26, 2007
SOURCE:
Which Is Better - Curtain Spring Rod or Curtain Spring Wire?
Both are very good alternatives to conventional solutions of hanging curtains, however, both have their share of pros and cons. As far as curtain spring rods are concerned, they can be an absolute bliss in terms of installation, a process that can take no more than 10 seconds. You will also not have to drill any holes through the walls which can be a blessing.
Extendable curtain rods are in very high demand because of their flexibility in terms of area of installation be it shower stalls kitchen windows or any others for that matter. On the flipside, general models will not be able to hold heavy curtains for which you will have to look for conventional solutions.
On the other hand, curtain spring wires / stretch wires are literally unchallenged in terms of neatness and strength. The only thing that can come in the way though, is the installation process which can be a little demanding especially for those that are not experienced in the matter.
Mar 14, 2018 | Home
What position is needle supposed to be in when you replace it. Is needle eye suppose to be facing you or is it to be threaded from the side?
Depends on your sewing machine. Most needle flat surfaces face the back of the machine so the eye is threaded from the front, but on some machines the flat surface faces toward the harp of the machine (so the thread is threaded through the eye from the left side).
FWIW, usually, if the bobbin loads from the front of the machine the needle's flat surface faces the back. If the bobbin loads from the left side, the needle's flat surfaces faces the harp.
If you install the bobbin, thread it, and it will not pick up the bobbin thread or create a stitch, then it is likely the needle is installed incorrectly. Also, installing the needle the wrong way could cause it to strike and break, so test it SLOWLY!
The ideal would be to consult the owner's manual. Search for:
Make Model manual
or
Make Model threading
Mar 19, 2017 | Sewing Machines
How to hanging curtain hardware
The most important thing with fitting hardware is to find the studs in the wall for brick veneer or in the case of solid brick, you must ensure the wall plug goes deeper than the wall plaster. The wall plug needs a hole drilled for a good fit- not loose or the plug will rotate as you tighten the screw.
Side openning - you can adjust the curtain postion after installation by lifting the cord from its clip on the carriage and moving the carrier along to the correct position.
On one of the carrier slides there needs to be an overlap for the little carry bar for the curtain hooks so you do not get a gap when the curtain is shut.
When designing curtains there should be at least 2.5 drops ( window cobverage) for a good looking curtain.
To prevent heat loss thermo syphoning up the window, you should close in the pelmet on the top. Just 3 ply will do this fine.
For one side pull, you need to screw the cord pulley end to the floor or skirtin via the spring provided and set the length of cord by shortening at one of the carriage slides.
I may be rambling here, but a simple stud finder is really handy to find the studs (vertical timbers) It also shows power cables but they will not be as wide. Any photos of your house under construction is good to show where the timbers and power cables are.
It is a good idea not to hit the power cables - tends to burn things - like houses.
Anyway if you describe waht sort of fittings you have you may get more useful info.
Dec 28, 2011 | Cameras
My onyx postershop 7 dongal lost
on installing I am facing problem (hardware key)
May 02, 2011 | Onyx PosterShop 7 for Windows Full Version...
Why am i facing problem to instal canon lbp 3000 printer in windows 7
Are you installing the printer using the correct driver for windows 7? If so and you are installing it using a cd/dvd, please copy all the contents of the cd/dvd to your computer and try install from the computer again instead of installing it from the CD-Rom.
If you don't have the driver, you can download it from here:
(click here)
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Canon Office Equipment & Supplies
Lost instruction manual for toyota 2400 sewing machine
just visit us at www.janomestuff.com to avail for a new manual
Sep 02, 2009 | Toyota Sewing Machines
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
JUST BOUGHT A FRIEDRICH CP08E10 AND NEED ASSISTANCE IN INSTALLING THE FRAME CURTAINS. THANKS FOR THE HELP. [email protected]
Solution is: you have to secure 2 small plastic supports that comes with the set after you have attached the side curtains with 4 small screws that are included. You don't need any extra parts or stabilizer. Thanks.  [email protected] July 29-08
Jul 28, 2008 | Friedrich Heating & Cooling
CanoScan Lide 25 scanner
i hv windows server 2003 on which canoscan LiDE 25 doesn't work i don't hv windows server 2003 driver .pl. help me.
Jan 11, 2008 | Canon MX700 Office All-In-One InkJet...
Goldstar R5050 Air Conditioner Logo
188 people viewed this question
Top Goldstar Heating & Cooling Experts
John Tripp
John Tripp
Sumeet Sodhi
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
