Question about Kenmore 60172 Electric Commercial Dryer
My gas dryer will not heat up. I have been unable to find any posts that match the model number. The model munber is 110.C74852301. I took the back off it and the igniter appears to be under the front of the unit. The bottom is sealed.
  • Kenmore Master
  • 8,220 Answers
Yeah you gotta drop the front panel using a putty knife to release the clips. Basically the flame sensor should have continuity. If it is open you the ignitor won't come on. anything that does not have continuity will be the problem. Their are 2 duct fuses, one on the heater chamber and one hidden behind the filter housing. READ MORE
Posted on Jan 31, 2009
The dryer works only when it when it wants.
what do you mean,does the motor run but no heat,also send the model number,open the door and look around the opening and you'll see a tag with the model and serial numbers,just send the model number and a little more detail,it will start with 110. and 8 more numbers
Feb 20, 2011 | Kenmore 73102 Gas Dryer
I have Kenmore Elite Electric Dryer Model 110 63932101 and it is taking like 80 min to dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 20, 2010 | Kenmore 64952 Electric Dryer
Kenmore Dryer won't heat
heatman101
Jun 01, 2010 | Dryers
Model number 110 97573220 gas dryer won't heat up to dry clothes, just runs and runs.
The ignitor that lites the burner to heat the clothes is probably bad should be located near the bottom on one of the corners inside the machine probably the could get to it by rmoving the back.
Mar 08, 2010 | Dryers
Hiya. My Kenmore dryer model 110 97282800 72828 will not dry (heats up slightly). Vent is clear and drum rotates. Adequate airflow coming from machine. Any help is greatly appreciated.
if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 73952 Gas Dryer
Can't get drum belt on Kenmore dryer
Generally belt comes around drum then around pulley tensioner and then back to motor pulley in a zigzag fashion
May 06, 2017 | Dryers
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 60172 Electric Commercial Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
