Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
No instructions need to know how to plumb into the main water feed, cant see where to plumb in
  • Admiral Master
  • 8,220 Answers
Open the cardboard dust cover on the rear of the ice box and connect your water line to the water valve. Here is a pic: no instructions - a8e6c7c.jpg
Posted on Jan 31, 2009
I had to shut off the main water supply due to a leak. Do I need to shut off the hot water tank also?
absolutely, the reason being is that the elements will evaporate the water till it below the element on top and burn it out. besides why pay to heat water u cant use. the water could also get low from doing some plumbing and the water drains out and u get the same result
Feb 09, 2017 | Water Water Heaters
What are the uses of plumbing?
Plumbing nowadays is specially used for small quantity water consuming in society building or in factory main supply from where the distribution of water is done via pipe line system called as plumbing. It is also said that, plumbing is the collection of connected pipes, it can be done in commercial as well as residential areas. The main goal of Assistance Plombier 77 is to reduce the wastage of water and to keep the environment clean and healthy.
Nov 12, 2014 | Watches
How would water get from upstairs bath to main floor if not the plumbing
Possibly high humidity is causing a buildup of condensation on the jot water line. One possible answer out of many. Need more info.
May 17, 2014 | Home
Get a shock from the tap while showering
I assume by main power feed your talking about the breaker box? If so make sure the breaker box is actually grounded. Also check inside the heater and make sure the ground wire in there is connected and has a solid connection.
Feb 17, 2014 | Rinnai Water Heaters
No water into dishwasher 8531654
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
After Isolating your appliance from the main switchboard,
Check that the tap is on feeding the line to the Dishwasher.
Check other taps in the house to see if your getting water to the house from the mains.
If its hard plumbed and the water is on, and still no water... check the inlet filter on the back of the dishwasher. make sure you have turned the power off first.
This could be blocked / obstructed with buildup grime from the water mains.
After cleaning the filters/ Checking the water supply and restarting the Dishwasher and you get the same error message you will need to call a serviceman to analyze the problem further. DO NOT attempt to dismantle the Dishwasher yourself unless you are a registered electrician or a qualified serviceman.
If its still under warranty call the manufacturer or the store it was purchased from, they can arrange a serviceman for you.
Good luck and Take Care
Dec 05, 2013 | KitchenAid 24 in. KUDP02CR Built-in...
My grundos water pump for my shower makes noises even when its turned off,does anyone know how i could fix this,thanks.
the feed pipes could be vibrating due to water pressure make sure the are fitted secure
Nov 11, 2009 | Plumbing
How best to install 3.5 atmosphere water pump to drive shower, bath, toilet and wash basin to two bathrooms, particularly connections to cold and hot water supplies?
Typically a water pump or booster pump would be placed on the main water feed (this assumes this line feeds not only the main cold line but the hot water system too. I work heavily with booster systems and would ask for futher information. Is this system runing off of a pressure switch such as starting a lower pressure and will shut down at a higher pressure or is it a constant pressure system where as the pump is expected to slow down or speed up to met demands? Either way the system will require a pressure tank, the first method of running will require a larger tank. With regadrs to connection this could be sweat in (with copper) or the use of mechanical connections. A proper "spring loaded" check valve would be required too.
I hope this may have helped,
Tom
Sep 21, 2009 | Plumbing
Admiral/Maytag fridge/freezer gc2227cdfb
no the water does not have to be plumbed in for the frige to cool. replace bulb. if short in the system exists then you will need to replace an interal wiring harness.
Jan 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have installed an AS 2555.501 Pressure Balance Vave and now the water pressure in the shower is low
this problem happens quite regularly as the valve will reduce the pressure but sometimes it will reduce too much, you can adjust it up, but you havent mentioned which type of shower valve it serves?
as the shower may not be suitable for the plumbing supplies it connects too , & how they are installed?
i am thinking its from the cold water main & that the valve requires storage feed instead of incoming water main supply? possibly thats why you installed a reducing valve??
Let me know?
Kindly
Richie
Dec 15, 2008 | American Standard 2555.501.295 Satin Town...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
66 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
