Question about ASUS M2N-MX Motherboard
Switch on problem with my system
When i switch on my system for first time the system is not switching on then.. i mean when i switch power button on my cabinet the cpu fan and power is getting on but the display is not coming then i switch off the cpu and immediately iam switching on the cpu then for second time the system is working normally.. once i shut down the cpu and then if i start the cpu again same problem my system is not getting started again i have to switch off the cpu and then i have to switch on the system it is irritating me alot so please help me out some one thanks in advance.......
Please you first switch turn on
Posted on Jan 31, 2009
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Intel D945GTP power comes for one second and suddenly off
open the tower/ ATX cabinet and then check the two small power cable pins that connects the power button on the ATX cabinet and the motherboard, remove the same from the motherboards end (make sure you note down from where you removed the 2 power pins and then using a insulated screwdriver short the power pins on the motherboard for a second until you see the power coming on let go of the pins as soon as you see the CPU fan moving if it stays on and works normally it is a faulty power switch on the ATX cabinet and then you can either replace only the power switch or get a new ATX cabinet to fix it
you can also check if motherboard stays on if you remove the RAM chip from the motherboard. if yes its a faulty Ram and replacing the same should do the trick
you can also try cleaning the dust accumalated under the CPU fan and between the heat sink as some motherboard cuts off the power depending on the temperature
also if nothing works you can try using a different power supply unit to see if that's the case,
if still no luck then its time to buy a new motherboard.
Feb 06, 2012 | Intel D945GTP Motherboard
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Computer is plugged into wall charger but will not turn on.
hi
diconnect the power cable from the CPU and connect it to the monitor if the LEDs on the monitor light up if yes the power cable is working else the power cable needs replacement
now connect the power cable to the CPU and have a look to see behind the CPU to see if the main fan is rotating....if yes then the SMPS (power supply unit) is working fine
check to see if the power switch and/or the Reset button on the CPU cabinet is anyway stuck if stuck then a slight tap on the side of the cabinet may solve the problem
if still doesn't work then the electricity is reaching the motherboard and the problem is a lil more internal and you would need some professional help
hope it helped
cheers
Jun 23, 2009 | HP Compaq Presario V6000T Notebook
CPU fan switching on and off repeatedly, computer not switchingon
Check the power supply switch of your cpu casing, make sure that it will not stuck when you switch on the power.
May 08, 2009 | Intel Motherboard
Going from 110 to 220 v.
have a look at the top back side of the CPU , near the smps fan where power cable is inserted. here u can find a small square cutting with a slider inside. On careful look you will find 110V and 220V inscribed on it on either end. Only one marking is visible at a time. Select by sliding this switch.
Note: Many systems do not have this facility. In that case you have to replace the power supply(SMPS) inside the cabinet.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Motherboard
If you use ATX power supply
Follow these steps
Switch on the power supply
Hold the power button approximately for 10 Secs , your system will be switched off. Now switch on the power supply and press the power button to return normal operation.
Some times pressing reset button also solves the problem
If above procedure fails , please check for any loose end connections inside the cabinet. memory slots, any pci slots also check the battery .
Hope this would help
Best of luck
Jan 29, 2008 | Computers & Internet
ASUS M2N-MX Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
