Question about Intel PRO/Wireless 3945ABG Network Connection (WM3945AGMW1WB)
Intel Pro wireless 3945ABG cannot find available wireless network
I've a VAIO FGN-FE with XP Media Center SP3 and an onboard 3945AGB wifi card that no longer finds wireless networks, either my own or neighbours' like it used to. I've tried updating drivers, rolling back drivers, uninstalled, restarted, automatically reinstalled with 12.2.0.11 drivers, restarted modem and router several times, and nothing helps.
The device manager reports no conflicts and the device is functional. Yet it doesn't function ;)
There is absolutely nothing wrong with the router (Dlink D-655) as other laptops in the home connects faultlessly.
Am ready to sacrifice to the Boffin God for practical solutions! cheers, Johan K/Stockholm
  • jkyl Feb 08, 2009
    Thanks - that fixed it! I wasn't even aware I had a hardware switch, which proved to be switched off (I must have fingered it inadvertently), and that did the trick. I didn't have ProSet installed, but I have it now, and the connection is now restored.
    Thanks a ton
  • pankuappu Mar 19, 2009
    Please Help me for God sake!
    My HP Laptop dv2601 TX has Intel® PRO/Wireless 3945ABG Network Connection , Its detects the neghibour's wireless connection but not the one, which is mine.
    Switch in front panel is on. I cant understand this mystery, it detects all other wireless in range but not the one which is in my room.
    This forum talked about, intel proset utillity. what is this, i have no idea... plzzzzzzzzz help meeee.
    Panki ...... Birmingham -UK.....Cheer
    Scholar:
  • 54 Answers
Did u check if the wireless radio is enabled in the computer or not just make sure the wireless radio is on.....
1st check the hardware switch first....
on the front panel you will see a swith as well as the wireless card indicator for the wireless,just toggle the switch and check if the wireless inicator light is on and off incase the light is on and the switch is turned off do the following step...
2nd click on start go to all program,you will see intel proset click on intel proset and you will see two options now click on intel proset utillity,out here in this box you will see enable radio check if it says the hardware switch is on or off,if it is off choose the option to on and click on apply and ok and then check..
now you should be able to see the network as well as it should be connected to the network...
incase both the hardware as well as the switch was on let me kno what error is it giving while you click to view the network...
it might a possible thing that you need to reset the wireless card.....u might need to take the card in and out from the computer...
best of luck...
incase you are stuck let me know..
vedhick
Posted on Feb 08, 2009
  • Ved Pradhan Feb 09, 2009
    hi...
    its good to know that the issue is resolved....
    take care and incase you face any problem...
    we are there...
    vedhick :)
Drivers free download pro wireless 3945abg driver driver version 11.1.1.11 xp sp3
you can download 3DP Chip v11.12 from Mediafire
Open it,and you will found Your driver like Example on the screenshoot,and Click it,you will Redirect to the Driver you've need.
Please don't forget to rate it if this helpfull.
Dec 10, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
Wlan driver problem in vaio vgn-cs21gn
Hi...
This is Nishit Jadawala from Ahmedabad, India. I am also having the same problem with my Sony Vaio VGN-CS21GN Laptop. WiFi was working perfectly in Vista but when I downgraded it to Windows-XP it started giving me errors that "Driver Not Found for the Device" I have downloaded all the drivers available on internet but nothing worked.
Finally after 8 months of research on this problem, I came to know that there is a bug in the supplied Windows XP-SP3 Operating System. There is a file in Service Pack 3 that doesn't allow drivers to access the hardware of WiFi.
The Solution is you will have to forget the bundled windows XP and upgrade your operating System. Right now better option is to go for windows 7. It dint even asked for any kind of drivers to load. WiFi is also working perfectly on it. The laptop has become more faster & smoother than in windows XP.
For more queries, you can write to me on mail.squarez@gmail.com
Thanks & Regards,
Nishit Jadawala (Film & Media Professional) Ahmedabad - INDIA
Dec 25, 2009 | Intel PRO/Wireless 3945ABG Network...
Sony Vaio XP Downgradation Wireless problem
Same Problem I am facing too. I am also having SONY VAIO VGN-CS21GN
Aug 17, 2009 | Intel PRO/Wireless 3945ABG Network...
Intel Pro wireless modem won't connect to my wireless router
Check whether the drivers for the motherboard is installed for the wireless Adapter card if it is onboard or if it is a PCI wireless card please reinstall the drivers using the software which came with that card. Thanks. It should work.
Jul 29, 2009 | Intel PRO/Wireless 3945ABG Network...
XP SP3 doesnt allow driver to get loaded
not a problem in xp sp3 under the device manager in system properties you will have a yellow circle and black exclamation mark and probably say unknown device or ethernet device. right click go to properties and in details tab you will see Device ID.. we can track OEM driver from this.
Jul 24, 2009 | Intel PRO/Wireless 3945ABG Network...
Intel PRO/Wireless 3945ABG Network Connection code 10
Code 10 usually means the device driver is not compatible, outdated or corrupt.
Try uninstalling the wireless device again and then reinstall using the latest driver available from:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2259&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version&lang=eng&strOSs=153&submit=Go!
NB If you're running XP, use the second one.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Intel PRO/Wireless 3945ABG Network...
Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Oct 14, 2008 | Intel PRO/Wireless 3945ABG Network...
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
Can't add new PC to extant WEP 128 network
If your system is encrypted you will need to set it up in xp before you open the media centre as if i remember there is no option to enter a password for WEP. Just open the network card properties and select the TCP/IP line then properties ans select obtain ip address automatically. Then when network is detected enter the WEP password numbers.
Mar 05, 2007 | Intel PRO/Wireless 3945ABG Network...
Computers & Internet Logo
1,375 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
