Question about Sony KP-44PX3 44" Rear Projection Television
Cant reset tv and the picture comes on 1 day and the next its blank like there is no singnil
Have no way of resetting the tv the dvd works have sound but no picture . when u manual chune the tv there is still no picture.when u atuo chune it say,s plese connet airel
I have not got a solution i tought u might be able to help please.
Posted on Aug 01, 2007
SOURCE:
Why cant I get tv sound
Be sure all your input cables are securely attached at both ends, make sure your internal speakers are not turned off.
Reset the TV by unplugging it for 30 seconds to 1 minute.
Also if you are using a cable/satelite box reset it by unplugging it for 30 seconds to 1 minute.
Do you have sound on another input such as DVD player.
if still no audio may have defective I/O-Main PCB
Jul 21, 2014 | Televison & Video
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
We finished watching a dvd movie with the sony surond sound dvd player and tried to go back to satalite and all i could get was no sig changed to all inputs and still nothing . I finally changed the cable...
Unplug,replug the tv about an hour later let the tv reset itself.Go into the tv menu,go to PICTURE go down to reset,this to reset ur tv Tuner signal board back to the factory setting.Those HDMI ports 1 and 2 should work again.Not than,ur Tuner signal board is defective,or the HDMI port 1 is shorted and dead.
May 31, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Turn on JVC 32" flat screen TV and got the JVC logo then sound and no picture. Then next day, only got the logo, no sound or picture.
There is a way to reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it. If i remember correctly you unplug the tv hold power button for 5 sec on tv then let go plug in and start. If that dont work unplug and then plug and hold power button on tv for 5 sec. It is 1 of those combinations. My tv worked after that. I googled my problem and a website listed that some tvs need to be reset.
Aug 16, 2009 | JVC LT-32X787 32 in. LCD Television
No picture
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 31, 2009 | Yamaha DVD-S540 DVD Player
Sound, but no picture
If you have a progressive scan button on the remote, it might change it back. Try all the video related buttons on the remote with the DVD player on.
Oct 19, 2008 | Cyberhome CH-DVD 300 DVD Player
No Sound on a Philips 42PFL5332D
First thing to try is reset everything to default.
Menu arrow to installation press ok.
arrow to reset av settings press right then press ok.
If still no sound after this the tv likely needs service..even if the settings assistant
has sound.
Sep 15, 2008 | Televison & Video
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
Sony KP-44PX3 44" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
