Question about HP Pavilion dv6000z Notebook
Having problems to connect router ( Belkin router & USB adapter)
I cant have the internet connection after connecting the router but the line comes on again. my IPS is ALICE. Please I need Ur help.
  • DEKR
    DEKR May 11, 2010
    you have the modem plugged into router
    did you have internet before
    do you see icon in taskbar for internet
  • Harrel Abalo May 11, 2010
    what other device are u using beside the router? is your ISP providing you a modem or something?
  • 21 Answers
Reboot the router and try again
Posted on Feb 28, 2009
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
Have dlink router but belkin wireless adapter cant connect
sounds like a security conflict, if you log onto the router and disable the wireless security will the laptop connect to the internet?
Dec 31, 2008 | Computers & Internet
Cant find own wireless
Set the SSID on at the router side. Alternately you can enter the SSID information manually at the computer side.
Nov 23, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cannot install my Belkin ADSL modem with wireless G router and wireless G USB network adapter
OK.
First plug your router directly into your computer via the ethernet cable that came with the router. You'll want to connect the cable to the port on the router that says "Internet" (it's ussally to the far left when looking at the back of the router) make sure the other end is plugged into your computer's Network Interface Card (NIC).
Plug your computer into the modem via the UBS connection.
Insert the setup cd that came with the router and follow the prompts.
Once configured then unplug the ethernet cable from your computer and plug it into the modem (which should have an ethernet (RJ-45) jack as well as a USB.
Now you can either hook up to the wireless connection using a wireless adapter OR you can plug your computer in with a ethernet cable to one of the outgoing ports on the back of the router.
Feb 23, 2008 | Computers & Internet
Cannot connect my wireless adapter to Belkin wireless router
Check and see if this setup guide matches your device?
Setup Guide
If it does we can probably search for more information.
Did you configure your router using WEP, WPA security (using passphrases) on your router?
Did you enable MAC address checking on your router?
Dec 15, 2007 | Computers & Internet
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Jun 23, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
HP Pavilion dv6000z Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
