Question about Frigidaire FEF352 Electric Kitchen Range
FEF352 - Burners will not heat up.
When I initially turn on the burners, they get warm, but they do not maintain the heat. They actually just go cold, as if I have turned off the burner. All 4 burners are affected. For the past week, they never get hot enough to cook anything. Please help.
    Problem Solver:
  • 18 Answers
Sounds like a power issue if it is all 4 burners otherwise if it is only one or two it is the infinate switch that controls the burner. if it is all 4 then pull the range out and open the panel that covers the cord connection and check for burned wires. next reset the breaker and try burners again
Posted on Jan 31, 2009
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
How do I keep the burners on at medium heat when I am making carmels so they get to the stage where they become caramels. My burners kept shutting off, so I had to turn them higher and when I got don
Is it the electric glasstop stove with the smooth top? If so, the burners aren't actually turning off. They're red until they reach the right temp and then they go dark to maintain the temp. If they stayed red the temp would keep climbing. I used one a while back and I remember it doing that. You didn't give much info, so that's my guess. I think most electric stoves do that to some extent, though. If it's gas, however, I'd call a repair guy.
Oct 01, 2017 | Kitchen Ranges
Hi i have installed a few bosch gas geysers at our lodge in mozambique.The problem is that the water gets hot when we turn the water on then the heat just shuts off and the water gets cold after a short...
The problem with all that type of water heater is that once the hot tap is turned on sufficient flow must be maintained through the water heater to keep the main gas burner alight. If the heat adjuster is turned up to high, then the person using the hot water will turn it down to a low rate which means the main burner will turn off and result in cold water. Try setting the heat control to the lowest setting that still gives hot enough water. If you have a thermometer adjust control for a temperature of around 50 to 55 degrees Celcius. You may have to fiddle with fine adjustments to get the temperature and flow rates to maintain a constant output of hot water. You may still have intermittent problems. If the heater only supplies baths or showers you could set the temperatuer even lower (45 to 50) to ensure that the hot tap is used more than the cold which will maintain flow and therefore heat.
Nov 22, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Should the burners go off and on
yes this is totsly normal
they are really not burners, they are elements, and you dont really cook from the heat of the burner, on this design, you actually cook from the heat of the glass, so as the glass cools through convection, the element will cycle, on and off to ensure the glass maintains a temp +- 25 degrees to the set temp
hope this helps
Oct 29, 2009 | Jenn-Air JES8850 Electric Kitchen Range
Left Front and Right Rear burner does not heat up
Both burners should be replaced as well as the recepticles that it plugs into. There are recepticle kits available for this repair.
Jan 11, 2009 | Frigidaire FEF352 Electric Kitchen Range
Fridgedaire Electric Kitchen Range
shut your oven off at the breaker and then pull it out and check the power cord where it connects to the ranges terminal block let me know what you find
Sep 11, 2008 | Frigidaire FEF352 Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
128 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
