Question about Toshiba Satellite A205-S4617 Notebook
Cd drivr not working Code 10
Hi, i have a toshiba satellite pro laptop running windows vista and my cd dirve is not working i went to device manager and i have a little balloon with an exclamation mark and it says "This device cannot start. (Code 10)" i was thinking of uninstalling, but if i uninstall it and turn my computer off and on again will it recognize it asa new gardware and install the driver itself or will it do nothing? Do you know of a better way to solve this problem please help me and thank you! Mervinh,
I have the same problem with my toshiba A205, alsom running windows vista. I followed your instructions, but before deleted upper and lower filters, I got a warning that said "deleting certain registry values could cause system instability. Do you want to permanently delete this value?" What kind of system instability should i be looking forward to, and is it possible to reinstall the upper and lower filters? Thank you so much for your help thus far.
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
L300 toshibi - vista i have a TSSTcorp cd dvdw ts-l633a combi drive fitted as standard to my brand new laptop but nothing appears on 'my computer' and device manager shows yellow ex mark against CDROM....
Hi there! Please run the following Microsoft tool in your computer.
http://go.microsoft.com/?linkid=9740811
More info:
http://support.microsoft.com/kb/982116
I hope it helps.
Feb 28, 2011 | Toshiba Satellite Pro L300 Notebook
I have a problem in my Toshiba pro L300 laptop. I have upgrade the operating system from Windows vista to windows 7. After that the CD-ROM does not detect any CDs and DVDs. I have seen the CD-ROM driver in...
Hi, this is a common problem, I have put a link below to do a free driver scan, hopefully it will detect the drivers you require.
http://www.opendrivers.com/modeldriver/Toshiba_notebook_Satellite%20M50-driver-download.html
Aug 04, 2010 | Toshiba Satellite Pro L300 Notebook
Running XP on a Toshiba Satelite L40-18X
I Have satellite L40-18W-PSL4CE laptop . I installed XP . i got all drivers except sound driver. the last sound driver was running on vista is (Realtek High Definition Audio System Software Ver:R1.72) on toshiba site they said this driver soppurt vista & xp but i got nothing after installing the driver. pls help me with greatfull.
Sep 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Hi Unveal
Your solution is simple just follow these instructions
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Toshiba Satellite A135 Notebook
All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Jul 22, 2008 | Toshiba Satellite P205-S6287 Notebook PC
CD/DVD drive isn't recognized / cannot load driver
what is your operating system? have you upgraded yo a higher version? if you did then you must have installed a driver thatis not designed to work withy our OS now.
Apr 01, 2008 | Toshiba Satellite A75-S211 Notebook
Toshiba A105-S2051 Pioneer DVD-RAM DVR-K17 wont read discs
you just remove cdrom drive from your device manager and restart your nonebook
it will reinstall cd drive automatically
Mar 26, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A205-S4617 Notebook Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
