Question about Baby Lock Esante
Bobbin problems! I have a Babylock ESE2, it is approx. 4 years old. I have a problem within the bobbin case area. As soon as I start my machine to embroidery, I can hear the thread catching on something, then of course the upper thread breaks. I have replaced the boobin case/shuttle-this did not remedy the problem. I don't see any thread caught anywhere. What can be the problem??? Help!!! Thanks in advance, C.Littleton
MAKE SURE you are using the correct SIZE bobbin. Some of the older plastic bobbins don't swap around in the newer machines & just because they LOOK the same doesn't mean they are. If you are absolutely POSITIVE you are using the right size bobbin (mark it w/ a permanent marker if you have to, to keep track of it), check & double check you are putting the bobbin in the case in the right direction & make sure there aren't any loose threads anywhere in the area where the bobbin sits... be sure all little dust bunnies are removed. I know it sounds redundant but get your book out & be POSITIVE you are threading thru all the thread paths in the right direction. My Babylock is supremely **** when it comes to putting the shuttle back in after I've cleaned the bobbin area & if I don't get it back exactly where it supposed to go, it won't sew right. I always have to get my book back & check it out again step by step. I have it do crazy stuff just because there was a little tail hanging out where the bobbin started to wind that I didn't cut off close enough.
Posted on Aug 04, 2009
  • 124 Answers
Hi and welcome to FixYa! I'm the expert that has chosen your issue to fix. Here's what I think:
This sounds like a bent or burred needle. Embroidery takes a toll on the needle and typically, they will only last for about 8 hours of use in straight stitch machine. Put a fresh needle in and see if this fixes the problem.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Posted on Jan 31, 2009
Why is my thread nesting on my Babylock BMP8?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Jan 14, 2013 | Sewing Machines
Bobbin jam babylock 1506
Ooo ouch! sounds like you have a pretty bad timing problem and or a damaged bobbin case. Since it is a baby lock I would suggest taking it in for repair.
Sep 08, 2012 | Baby Lock Sewing Machines
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
I have an Esante ESe2 and am having trouble with the upper thread breaking. I have checked bobbin case for fuzz and thread, re-wound the bobbin, re-threaded everything and nothing helps! Please help me...
Open the top part of the machine. My mom just bought one and it had lots of thread inthe thread path of the thread on top. You have to open up the area that the thread runs thru. It solved her problem of thread breaking. She found lots of thread inside.
Dec 16, 2010 | Baby Lock Esante
Babylock espire bobbin sensor not working
This is normally caused by lint in the bobbin area, the lint blocks the sensor causing it to be blind. Try cleaning the area and see if that helps.
May 28, 2010 | Yamata FY101-1A
Flywheel locked up on Babylock Ellegante. No threads tangled up anywhere.
When you removed and replaced the throat plate, bobbin and bobbin case to clean the shuttle and surrounding area, did you have the needle at it's highest position?
If the bobbin case is not properly re-installed, the hand wheel is affected.
If all of the above has been done and the handwheel is still locked up, the machine will need to go into the shop for service.
This is an expensive, computorized machine and any additional hands-on troubleshooting could add up to a costly repair fee.
May 16, 2010 | Sewing Machines
Problem with my Babylock embroidery machine
I think you may have forgotten to put on the Q presser foot.
Feb 16, 2009 | Baby Lock Esante
Thread gets caught on bobbin and jams
You may need a new bobbin case if your machine is an older model.. Over time the cases get nicks in them causing thread to catch on it. Have you lubricated the bobbin area? Needs one drop of oil for every ,I believe it is 25 hours of usage. That may take care of it. The oil goes under the bobbin right in the center of bobbin case. Remove your bobbin before applying the oil. i hope this helps you. Good Luck
Jan 08, 2009 | Janome Harmony 2039 Mechanical Sewing...
My Bernina 930's lower tension is off. When I sew the stitches are tight on top, but loose on the bottom. How can I fix this? I've tried messing with the tension and have cleaned the bottom.
Hi - you might have a dirty bobbin case, or need a new one. IAfter awhile, little teeny dust bunnies can collect in your bobbin case and cause your bobbin tension to go wonky, especially if you use cotton thread. If you happen to have an extra bobbin case, try using the new bobbin case to see if that solves the problem. Otherwise.....
  • Remove your bobbin case and take out the bobbin. Find a small, stiff brush like the one that came with your machine and stand in very good light. Brush out the inside of your bobbin case, and push one or two bristles of your brush into any opening you can see. If you see any trace of dust but you can't get it out, use tweezers to gently pull the dust out. Now look at the outside of your bobbin case. In the small opening where you insert your bobbin thread into the bobbin case, there is a small piece of metal with screws in it the lays over the bobbin case. Brush that area carefully, and again, insert one or two bristles under than piece of metal and into any other small opening where the bristles will fit. Try sewing again. If you are still getting loops, take out your bobbin case with the bobbin thread still inserted and grab the bobbin thread with two fingers. Let go of the bobbin case - sort of like you are holding a yo-yo. If the bobbin case starts to drop as soon as you let go, your bobbin tension is loose. If the the case doesn't move, gently snap the bobbin thread you are holding and see how far the bobbin case moves down toward the floor (you might need to try this a couple of times, the bobbin has a nasty habit of flying out). When you do the snap, the bobbin case should move down about two inches and stop. If do not know how to adjust the bobbin tension, either check your manual or take the machine in for service.
  • If you haven't already, it's a good idea to remove the thread plate that sits under the needle and clean that area out with your brush. Also, get a really good flashlight and check the area where you insert your bobbin case. Gently turn your fly wheel and look inside the hook area - remove any dust or bits of thread.
In general, you should oil your machine as indicated in your manual as often as directed. You should change your needle every 10 hours of sewing - or each time you start a new project, and you should take your machine in for service every one or two years - even if you only use it once and awhile.
Hope this helps, Ginny
Dec 06, 2008 | Kenmore 19365 Computerized Sewing Machine
Babylock Espree
If the machine is threaded properly, the tension is set somewhere in the middle, the bobbin is the correct size and the needle is inserted properly then you probably have a problem with the bobbin case. Remove the bobbin case and examine it for any kind of scratch or rough spot or needle puncture. If you find such a spot you will need to polish it with emery cloth or something very smooth.
sewman7
May 16, 2008 | Brother PE-150V Computerized Sewing...
Sewing Machines Logo
694 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
