LG plasma 42" tv 42PT85
Hi I have the above tv it has a hardrive to enable to record to the tv, we are having problems whenever you are recording or set the timer, the tv freezes up, you cannot change channel or turn tv off, so the only solutioni s turn off at wall, which then cancels what you was recording, any ideas, thanks
  • Tim Gilpin Mar 15, 2009
    Same problem. Seems to be a common fault. All I can find on net is LG say 'not a viable repair' which seems crazy! My set is just over 12 months old and this has been happening for months. LG are saying only 12 month warrenty so out of luck! I'll keep trying anyway.
bluegreenash
  • 661 Answers
SOURCE: RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Posted on Sep 27, 2007
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
I have the exact same problem with my 42" LG plasma which is about 3 yrs old. Turned it on one morning and had verticle lines all over it with only the sound playing.
Posted on Jul 07, 2008
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
Hello I have just got a Sony PFM 42VIE television. How do I connect it via cables to be able to pick up tv broadcasts vis a panasonic dvd recorder with built in freeview. Thankyou.
Hi, The simplest way to connect the dvd recorder to television will be via the coaxial connections(the cables with the screw on ends)- ( on dvd recorder one will say in from ant./cable the other will say out to tv ) this should enable you to change your tv's channel with your dvd recorder which is what you're after I assume. The best connection will be with the dvd recorders HDMI output or component video out, keep in mind they may only work for dvd viewing and not with tv channels, also hdmi ouput has audio built in-with component video you will need to connect dvds L/R stereo output to the audio input for component video ( these connectors are marked red,green and blue.) the stereo input will be red and white.Thanks and I hope this was helpful, good luck Prodzilla
Apr 13, 2011 | Sony PFM-42V1E 42 in. Plasma Television
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
Jul 06, 2010 | LG Electronics 42 in. LCD Tv
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Recording from LG 42pc1dv plasma tv to LG v782w VCR
If it does this on all channels then the video on your AV out from the TV is bad.
If it only happens with some channels then this is Macrovision protection working which will not allow you to record premium channels and any that are using this protection.
Aug 10, 2008 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
LG HDTV large screen is blank but guide/list/pip shows up
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Apr 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
How to connect to digital cable box and TIVO
Click here and start at page 24 to see a diagram on how it should be hooked up.
Sep 23, 2007 | LG 42PC3D 42 in. Plasma Television
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
