Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Green and purple band of color
I have some double imaging and a purple and green wavy band of color on the bottom of the screen went away once but came back and stayed
  • 1 more comment
  • Anonymous Feb 08, 2009
    double images and a green and purple line on the bottom.
  • toojax Feb 15, 2009
    i have wavy green and purple lines 3/4 of the way across the bottom of the left and the remaining 1/4 of the colors on the top right both about 8" up and down the screen
  • lizardamos Mar 17, 2009
    purple and green double band on the bottom of the screen and the rest of the picture is distorted.
  • Panasonic Master
  • 3,459 Answers
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
green and purple band of color - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
you're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Jul 30, 2009 | Samsung Televison & Video
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
Double images
Convergence amps bad call a tech make sure he does'nt use generic parts A Toshiba service center should know what to do around 300.00
Apr 12, 2009 | Toshiba 50H82 50" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Purple and green strip/shadow around all the images and at the bottom
Either a bad optical block or possibly a bad LVDS cable, you need a qualified tech to know for sure
Sep 19, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
