Question about Cell Phones
My mobile is working but not charging (battery is good)
Could be the charging pin at the bottom of the phone
Posted on Jan 31, 2009
How do I know if the battery is fully charged and working
Hi, the ideal situation is to charge them with a known good charger
Regards
Rob
www.gewizrepairs.co.uk
Oct 10, 2014 | Pride Mobility Products Go-Go Elite...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
My 6300 wont switch on. {battery is charged} iv used a replacement none nokia battery,it was working ok. it wont charge either
Hii
Firstly never try to use local battery because they are not good enough and damages handset .
check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required.
Update your handset and never use local battery always use nokia brand.
Thanks to help you
Aug 20, 2011 | Nokia 6300 Cellular Phone
I had replaced with a new battery and its just worked for one and form after next days it dont get charged.....the shopkeeper says the mobile is not getting charged.......
In case the battery is not getting charged. It can be due to 3 reasons
1. The power adapter through which you are tryiing to charge the battery is u/s Check with another adapter and see if its charging then the problem is with the charger else.
2. Take out the battery and put it on another phone and try to charge it. If it is charging then the problem is with the mobile charging point and not the battery. If not charging then the problem is with the battery only.
3. Mobile charging point is not working due to which the battery is not charging to check this out just put your battery on another phone and check if its charging. If charging then you are required to get your charging point on your mobile repaired.
Feb 04, 2011 | Motorola Mobility ROKR E8 Cellular Phone
WHAT ARE THE NEWEST AND LONG LASTING BATTERIES I CAN BUY FOR MY MOBILITY SCOOTER. I WANT TO TRAVEL FARTHER THAN THE 20 MILES WITHOUT RECHARGING THE BATTERIES. ALSO I WOULD LIKE THEM TO BE SMALL AND LIGHT...
Hi. When you are looking for good quality batteries, they will have a 1 year warranty on them. If you get offered only a six month warranty, don't buy them. Good batteries weigh more than cheaper batteries, because they have more lead in them.
To get a good distance, you need to fit the biggest batteries that will physically fit in your machine.
Batteries are designed to handle a certain number of "charging cycles". If you run a battery down by approx 75%, you will only get a small number of "charging cycles". If you only use 25% of the batteries capacity, you will get 100's of charging cycles.
Gel batteries seem to be the better choice. Most AGM sealed batteries are designed to be stand-by batteries. They will work fine in your machine but only for light use. I have seen these batteries last for 7 years, but only for light use.
Good luck. Neil.
Jun 02, 2010 | Electric Mobility Pacesaver Electric...
I have an electric scooter chair that would charge, do i need to replace the battery? i had not charged it for about a year and i think the batteries are drained. I tried to charge it and it is not holding...
Hi. Sounds very much as if your batteries need replacing. Batteries loose there ability to hold a charge if they are left for long periods of time.
Some times repeated charging and discharging will help, but will not be as good as new ones. Good luck. Neil.
May 29, 2010 | RTO Mobil Line Mobility Scooter Chair...
I have a chair that is two years old and has never been used. Charged it up for two days but it still won't run. Perhaps it needs a new battery as the battery was never used. My mom hated the chair and I...
Hi. When you charged it up, did the battery indicator lights on the control panel light up?
If you take the batteries to a battery shop, they can some times get the batteries to take a charge.
I have had a few batteries that have been sitting for a long time, what I do is charge them seperately for a few seconds on 24 volts. A quick charge of 24 volts across a 12 volt battery will sometimes break down the sulphate that builds up on the internal plates of the battery. Once you have done this. charge the battery properly, and then discharge it, ( you can use a light bulb ).
Charge and discharge the batteries 5 or 6 times over the next few days. This will hopefully let the batteries take enough charge to let someone try out the machine. The batteries will not be as good as new ones, but if you are donating the machine, they could buy their own batteries.
Make sure that when you are working with batteries, you use good safety rules, batteries are dangerous, and will give of hydrogen gas, which can explode. If in doubt about your abilities, get the battery shop to charge them for you.
Good luck. Neil.
May 11, 2010 | RTO Mobil Line Mobility Scooter Chair...
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
Battery Wont Charge
either the battery is drained so its not getting charged. remove the battery from the cell and check out.or the charger is faulty so need to replace the charger.sometimes pressing the pin of charger in to the cell gets connected internally and the charging starts try it.other wise that two above things need to be checked.
Mar 02, 2009 | LG ALLTEL AX275 Cellular Phone
Cell Phones Logo
413 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
