Question about Canon imageRUNNER 1310 Printer
How to replace imagerunner drum? - Canon imageRUNNER 1310 Printer
  • Josh Lloyd May 11, 2010
    Replacing a drum is a complex process best completed by a trained technician. It is not considered a user replaceable part.
    Replacing a drum is a complex process best completed by a trained technician. Unless I am mistaken, it is not considered a user replaceable part.
E000020 1360 canon error code after changing drum unit.
This has been fixed by replacing the memory chip on the drum. This may meaning replacing the drum. First though, try cleaning the laser and make sure all your drivers are upto date:
http://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c2025i.aspx?type=drivers&language=&os=OS%20X%2010.11%20(El%20Capitan)
This may be a call to canon support unless you are very confident with these procedures.
Part number for the drum is Canon C-EXV34
May 23, 2013 | Office Equipment & Supplies
HOW DO YOU REPLACE THE DRUM IN A CANON IMAGERUNNER IR1600 COPIER
do you mean complete drum unit?
If yes, you need to open front cover, realese the blue handle, remove the left sideway cover ( cover above the bypass tray, that have handle in the middle and goes out in left direction - TRANSFER COVER ), you will see two handles, left and right of the drum ( green roller ), grab them and pull the drum unit out.
Reinsert new drum unit, put back the transfer cover, lock the blue handle and close front cover.
Hope that helps!
Aug 23, 2010 | Canon ImageRunner 1600 Copier
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Double images showing up on imagerunner c6800 when using color copies only
unfortunaly to tell you the only real way to have this problem fixed is to replace the drum and the drum blade.... though it might be possible to clean the drum depending on how bad the drum has gotten
Apr 20, 2010 | Canon imageRUNNER C6800 Copier
'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Mar 01, 2010 | Canon ImageRUNNER 1670F Copier
Problem on Canon imageRUNNER C3200 Copier Error Code We have an error code of e000020-04b0
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
Nov 04, 2009 | Canon imageRUNNER C3200 Copier
System Error E810 - how do I fix?
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is amiss in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear. Use cation when removing, as the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit(expensive) approx. $135 for GPR 10 Drum unit.
Jun 02, 2009 | Canon imageRUNNER 1370F All-In-One Laser...
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 1310 Printer Logo
159 people viewed this question
old marine
old marine
