Question about Kodak EasyShare LS443 Digital Camera
Camera stopped working
Recently, this camera stopped working. Initially, the light next to the viewfinder would blink red 10 times and the camera would shut down. Now, it doesn't blink at all. I've placed the camera in the dock, but it still won't turn on. I've replaced the battery with the same results. I've taken out the battery and memory stick, then replaced them...no go. Kodak is no help. There was some sort of error code before it went belly up. It was pretty quick, but said "Error 84--" (possibly 8416). Any suggestions?
  • Anonymous Jul 31, 2007
    Thanks...I thought of that. I was hoping there was some sort of fix, though. I've also discovered that the camera/dock is not charging the new battery. I'm guessing this also has something to do with it.
    Genius:
  • 2,985 Answers
If Kodak are not come up with ansers - who can? New camera perhaps is the answer -not a Kodak this time
Posted on Jul 31, 2007
    I not know the battery- but investigate a third party charger that will do the job
    but problably you wont get any where .
    New camera then
SOURCE:
When I try to take a pic, the camera beeps and a red light flashes.
Hi. Based on your brief description of the problem I would think that the camera is failing to focus and the flashing red light in the viewfinder is the auto-focus indicator, make sure that the red auto-focus indicator is positioned in the centre of the viewfinder initially until you have experience of using it (to do this consult your camera manual) focus on a subject that has some contrast ie a red brick wall, grass or pebbles on a beach.
Apr 15, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
The HP Photosmart R707 Viewfinder video light keeps blinking in red even when the Camera is switched off.
If you actually mean the power light, that is supposed to blink when you plug it in and it is charging.
If you mean the one in the viewfinder, that is an error condition, and an error message is supposed to show up in the back image display viewer.
There may not be enough battery voltage left to display, so plug it into the AC adapter to be sure.
Aug 14, 2010 | HP Photosmart R707 Digital Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
When I close the viewfinder, red light keeps blinking.
i think that most do that, just hold the power button next to the "DIRECT DVD" and "UPLOAD" button, towards the left. =D
Jan 09, 2009 | JVC Everio GZ-MS100 Camcorder
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Flashing Red Light
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Sep 24, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Everything freezes with a red light after I take a picture
Hi
I had simular prob,,
ended up it was my batt
got new 1 on e-bay camera fine now
May 29, 2007 | Vivitar ViviCam 4000 Digital Camera
Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
Dec 06, 2006 | Panasonic NV-DS29B Mini DV Digital...
Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Oct 16, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Kodak EasyShare LS443 Digital Camera Logo
76 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
