Question about Sony MDS-E10 Mini Disc Player
Displays message " I I C STOP"
When I turn on my MDS-E10, nothing works and the screen reads I I C STOP Whay's the problem? Thanks
3 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: i have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
Posted on May 15, 2009
TOLhamRadio
  • 509 Answers
SOURCE: Read Error
Does he have a pre-recorded MiniDisc that he can try it with? It could be that a cable wormed its way loose, or the laser took a dump during the shipping. Hard to tell. Try the pre-recorded disc first, then you might end-up having it back.
Posted on Sep 01, 2009
I can not load disc. The display blinks IIC STOP
1) A good first step would be leaving the unit unplugged from power for a few days and see if it resets anything.
2) READ YOUR OWNERS MANUAL.
3) Buy another one.
Jan 28, 2014 | Sony MDS-E10 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
MDS-E10 will not eject disc
The lower end mechanism were full of problems after about a year of use. The unit needs to go to an appropriate Technician- NOT Sony as they will just replace the mechanism if they even work on it and it will be the same cost of a new unit. The mechanism you have needs lubrication and a limiting resistor placed in line with motor to not break plastic parts.
Jan 27, 2013 | Sony MDS-E10 Mini Disc Player
I have an MDS E10. If you touch the top or sometimes the front, the display goes off and comes back on just like you just turned it on. I looked inside for loose cables but couldn't find any. I made...
I've had similar problems with older Pioneer displays, they do wear out in time. What worked for me was placing a shim made from a cable tie near the ribbon cable going to the display moving the cable into a better position.
This may not work for you, the display may be near failing due to old age I'm sorry to say.
Aug 16, 2011 | Sony MDS-E10 Mini Disc Player
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
I have a minidisc model mds e10
or
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
Read Error
Dec 12, 2008 | Sony MDS-E10 Mini Disc Player
Sony MDS-E10 has been dropped. need schematics to solve problem.
Your service shop would need to purchase the service manual (if available). The problem here is that without seeing the unit, I can;t tell you whether the optics are bad or the tracking head is bad or the loading mechanism is defective. None of those options are cheap. Let me look into this a bit and see what I can find. I will try to get you part numbers at least with costs.
Dan
Nov 25, 2008 | Sony MDS-E10 Mini Disc Player
Sony MDS-E10 Mini Disc Player Logo
196 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
