Question about Desa International R40 Utility Heater
My 55,000 BTU Kerosene heater Model # R55 will not fire
When I plug my heater in the motor statrs but emits a clod of smoke
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Time for a Full overhaul kit!
Posted on Dec 18, 2009
Have a R35a that was stored with kerosene for 2 yrs. Electric motor runs and it tries to ignite. belches some smoke and heat intermittently then just blow air
your pic is a propane heater but model # a kero heater any way check lines to the air and fuel for cracking filters have to be clean in the heater and foam on the out not sure what the pressure is for that model but findable table on the ready heater look up get the old fuel out and new in good luck ready was the best
Nov 30, 2013 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater R55 55,000 BTU heater spits and sputters but CONTINUES TO RUN. Air pressure is at 3.4 (was 4.0). new lines, Plug is firing well, fuel is old but clean. My question is: is there supposed to be...
If you brought the heater to my shop with the great (no lie!) description of the problem we would immediately grab a flashlight, shine into the tank and look for water droplets rolling on the bottom of the than. (Keep in mind that a layer of water can be on bottom & not show up with the light)
The next thing would be to use soapy water and try to find a crack in or around the plastic cover and move all the way to the nozzle looking for an air leak. 3.4 at the gauge doesn't mean the air is going all the way to the nozzle.
Next, remove the top cover. Does the heater run fine once removed? If so, replace the worn out nozzle. That heater has some age on it and DESA recommended annual replacement.
The filter is more of a strainer than a filter. It is hollow.
Read more troubleshooting tips.
Nov 10, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a 55,000 BTU Kerosene heater that will not fire up. The fan, ignitor are all working. What could cause this?
The fuel is drawn from the tank by vacuum. If there is any kind of dirt in the fuel or tank, it will clog up that tube and not fire up. Also there is a foam filter at the rear that could be dirty. There is also a reset button by the filter that needs to be reset every time it runs out of fuel.
Oct 27, 2009 | Reddy Heater 60,000 BTU Kerosene...
I have a portable forced air heater Model R55A heater size 55,000/Hr can I use diesel fuel instead of kerosene?
You can, but prolonged use of diesel fuel will burn out the cone faster. Too hot. And it stinks alot worse than kerosene.
Oct 14, 2009 | Reddy Heater-30-55,000 BTU Variable
Hello, I have a 55,000 BTU kerosene heater, model # R55 It will not fir or ignite when I plug it in. Just paid $10.00 for a guaranteed online answer and have not received one
Take air preassure from a compressor and turn the fan blades in the back of the motor while you reset the switch. the you know its gumming up and needs to be cleanned and changed parts or a kit added from your local lawnmower supply house.
Jan 31, 2009 | Desa International R40 Utility Heater
Will not start unless top cover is off
Check that the fan is clean and unobstructed. It sounds like something may be cutting down the air flow. Or the cad eye may be faulty or dirty.
Hope this helps.
Matt
Jan 08, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Desa International R40 Utility Heater Logo
390 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
