Question about Samsung Digimax S600 Digital Camera
Samsung Digimax s600
My camera's lens does not does not extrude outwards/inwards when i go turn it on/off unless i twist it a little. i think some dirt may have got inside it, can this be cleaned easily or can i get a new one with the one year guarantee
    Genius:
  • 2,985 Answers
Well cleaning will not be easy- you could try vacuuming it to see if any dirt can be sucked out, But yes a new camera is the more economical option and you will get the latest spec too.
Posted on Aug 01, 2007
SOURCE:
Hi i have problem with Samsung cyber630.. I bought a card http://www.alfacomp.cz/php/product.php?eid=1051400821MM1S8CI4 and when he starts to turn on the camera lens, but does not turn up. Plese help
I have had this problem before as well. Your camera only accepts SD cards, not SDHC.
Be careful an look to make sure it does not say SDHC on your next purchase.
You camera manual can be found here.
Mar 26, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
I own a Digital Camera DIGIMAX S600 ..... My problem is when I do photography, the camera shut down it self .. And when I restart the camera is not working ..... What is the solution ???
The Camera is on an error due to failure of the control system... maybe possible the servo of the lens/ shutter section You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
get estimate before you decide. It will be good to have it checked at the Samsung service as you do not have to run around for spares even if you can open to confirm a failed board/part.
Nov 26, 2010 | Samsung Digimax S600 Digital Camera
The lens won't open/close and it beeps three times instead
the camera was last on the batteries were either extremely low, or they died and lens could have been kinda off track a little when it happened so it got stuck that way….Put in new batteries and If you lay the camera flat facing up at you and you look down and lens looks a little crooked….Push it slightly in the direction it needs to go to get back on track and when you hear the pop noise it’s fixed. Then when you turn the camera on if it stays on attempt to zoom in and out and the lens will then get back on track…and then TUrn it off and the lens should go back in
Jul 06, 2009 | Samsung Digimax S600 Digital Camera
Lens,not close properly
If it is your camera's time to go, there is no helping that. Most likely a grain of sand has found it's way into your camera mech. You can turn your camera on and off while banging it on the counter gently, but it is unlikely you will succeed, due to most lens parts use a sticky lithium grease for lubricant.
Nov 13, 2008 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
JAMMED LENS
The track inside of the lens and maybe other damage has been done. This is something that you cannot do yourself, unless you are trained, have access to the parts, and experience in camera servicing.
You should send the camera to the manufacture authorized service rep for an estimate.
Apr 14, 2008 | Samsung Digimax S600 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 drivers
Hey there Here you go: http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=s600 For the drivers http://www.samsungcamera.com/product/pro_view.asp?prol_uid=1168&cat_uid=11 For all information Enjoy
Sep 02, 2007 | Samsung Digimax S600 Digital Camera
I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
May 20, 2007 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
