Validation help me with the validation of textbox so that user would be able to enter only number or character
  • M Norwood May 11, 2010
    Which programming code? Which development environment?
    President:
  • 392 Answers
I suggest you this website:
http://www.codeproject.com/
Good luck friend
Posted on Feb 09, 2009
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Validating textbox, the textbox should be accept numbers only Im using a PL vb6.0
Put the following code to txtBox_BeforeUpdate function:
If IsNumeric(txtBox.Text)=false then msgbox "Numbers only"
Feb 14, 2010 | Computers & Internet
Though i am entering valid new password, i am
Yahoo is recently having this issue and I'm sure they are on their way to solve it.
For now use a six digit password with six or eight digits and use only numbers and alphabets; don't use special characters like . /%& etc.
Nov 29, 2009 | Yahoo Mail
Can't connect with microsoft MN-510 using WPA
This means that you have to enter the network key into your computer in order to connect to the network,
If you enter the password as hexadecimal characters, you must type exactly 10 characters (5 bytes) for a 40-bit key (valid characters are 0-9 and a-f), or exactly 26 characters (13 bytes) for a 104-bit key.
If you typed any number of characters other than 10 or 26, or any character that is not a hexadecimal digit, this is interpreted as ascii string.
In this mode, each character is a byte by itself.
So, valid length of the string in this case is either 5 or 13 characters.
If this condition is not met, the string can't be accepted as a valid password.
Please check carefully what you type. (Letter O instead if zero, or small L instead of 1 etc.)
If you don't know the key, you have to connect to the router via a cable and copy the key from there - or ask your Dad to give you the information. He will have it, because he has a working connection.
If you have any more questions or this is not clear ot you, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Microsoft Broadband Networking MN-500...
Text box restriction
I hope this helps and thanks for rating my effort...any other questions...shoot em to me....The Fang.
Restricting character input You can use the SetInputTextType command to restrict the characters that the user can enter in the text input dialog box. For example, suppose an application contains an input text field for users to provide a numeric value, such as their age, and that the input text field has the variable name ageVar. To ensure that the user enters only numeric values in the text input dialog box, you could add the following code to your application:
fscommand2("SetInputTextType", "ageVar", "Numeric");
When users open the input text dialog box, they can enter only numeric values in the text fields.
For more information, see SetInputTextType in the fscommand2 function entry in the Flash Lite 2.x ActionScript Language Reference.
May 28, 2009 | Adobe Flash® CS3 Professional Full Version...
Microsoft access form problem
In the Design view for your form element (eg textbox), go to the Data Tab. Look at the options for:
Input Mask, Validation Rule and Validation Text. You can use any combination of these to force a user to enter something in the field. If you just want to check that the contents of the element has a non-zero length, then you can write an event (Events tab) to check the length of the values entered. If 0, then throw a message box and re-focus the cursor on the textbox.
May 19, 2009 | Microsoft Access 2003 for PC
What if i want user to only enter character in a textbox?
The field should be set as an ALPHA ONLY field! I am talking from the data base side of programming. In data bases you set a field as Alpha, Numeric, or Text. I am not sure if you will have the same options.
Apr 17, 2009 | Macromedia Flash MX Pro 2004
Validating in jsp
JavaScript Form Validation JavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required Fields The function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
} The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
} function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head> <body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body> </html>
E-mail Validation The function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head> <body>
onsubmit="return validate_form(this);"
method="post">
</form>
</body> </html>
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Sun Java Programming Language (cdj-275)
Extra characters display when key pressed
Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
Cheers!
J the Guru
Aug 12, 2017 | Microsoft Visual FoxPro Professional...
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
with (field)
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
with (field)
else {return true}
}function validate_form(thisform)
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
with (field)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
Mar 04, 2009 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
