Question about Harman Kardon HK695 Computer Speakers
Opening the Woofer
My daughter's HK695 is blowing fuses. Not real fast but after a few hours of playing, even at low volume the fuse will blow. I want to open up the woofer (which contains all the circuitry and controls) and take a look. I removed all the screws in the base but I can't seperate the base from the shell. Any ideas? Thanks In Advance, Pete
  • Anonymous Aug 09, 2007
    Sanchit,
    I already removed all the screws. There is a crack between the shell and the base and if I pull real hard I can expand it to about 1/8 inch on one side and almost nothing on the other side.
    There seems to be something inside that is keeping the two parts together but I can't get to it.
    Thanks
    Pete
Pete C - I had the same issue, and the same frustration.
The key is-> the floor bumper on the back side has a hiden screw under it. Remove the bumper, then stick a hook in the hole to pull out the plastic plug, then the screw is accessable. Good luck on finding anything inside.
Posted on Apr 02, 2008
I got one HK695 and faced exactley the same problem opening the woofer.
First remove all the screws down under the base then remove the safetynet and then the element. From there it posible to seperate the base from the shell after the screws are remowed.
Posted on Mar 12, 2008
The base and the shell might be screwed of soilded. if it's screwd then unscrew it and if soilded then slowly try to break the soilding
Posted on Aug 04, 2007
SOURCE:
Pioneer 74txvi fuses (fast or slow) burning
If there is nothing left inside the little glass tube, it's a fast blow. A slow blow fuse will usually have a spring and some other material that make up the slow blow mechanism. slow blow fuses used to also have 'SB' stamped on the metal end caps. The fuse holder may also tell you. If you cant figure it out, put in a fast blow and see how long it lasts, If if blows when you turn the volume high, you should try a slow blow.
Jan 22, 2015 | Pioneer Audio Players & Recorders
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
E315 cerwin vegas speakers and one keeps blowing a fuse when I turn it up to the normal volume I play them.Can I use a bigger fuse or is it the speaker?About a yr old rarely used until the last few mo
Try playing the speakers at a friends house or something to see if you blow their fuse. If you don't then you know for sure that you need a bigger fuse, but if you do then it's the speaker.
Jun 03, 2013 | Audio Players & Recorders
1994 cadillac eldorado - fuel injector fuse blows out randomly
take a ohm meter and see if one injector has high resisance
Sep 12, 2012 | 1994 Cadillac Eldorado
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
My fan fuse blows when it gets hot
About the only thing that would cause the fan fuse to blow is either the fan has a problem and is dragging or a short in the wiring. I would bet the fan motor is probably bad. The hoses and thermostat have nothing to do with the fan motor fuse blowing.
Jul 29, 2009 | 1993 Acura Legend
Pioneer VSX-D511 Comes up with AMP ERROR and shuts down
I must agree that if the fuses are open and you replace them that your problem maybe fixed. If you can remove the fuse, I recommend taking it to a RadioShack and see if someone there can figure out what it is. I am going to assume that the fuse should be a 250 V. If you can find one that matches the same appearance, go with the smallest aperage rating you can find. Go with this route only if the person can not tell you exactly what it is you need. Be sure to match the type of fuse if you can see inside it like in the case of a glass fuse. Some are slow-blow fuses and some are fast-blow. If you are uncertain your safest bet is to use a fast-blow with a real low amp rating for the voltage you are using. If the amp rating is too low, it may run fine at lower volumes and pop when you turn it up. If I could physically see the fuse, I would probably be able to tell you what it was and what you needed to replace it with.
Jun 06, 2009 | Pioneer VSX-D511 Receiver
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Apr 25, 2008 | Car Audio & Video
Harman Kardon HK695 Computer Speakers Logo
372 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
