Question about Kenmore Elite 45986 Front Load Washer
Bad drainage but no error message
The cycle is going full cycle and I don't have any error messages but there is water left in the machine. Any ideas what the problem may be? It will finally drain if I use the drain and spin cycle. Also, when that happened, I had water coming out of the machine and I don't know where from (I wasn't there).
Help  Please.
Thanks.
    Problem Solver:
  • 18 Answers
There are 3 screws (probably torx bits) at the bottom panel on washer. remove this panel and then you will notice the front of the pump unscrews. lay a towel down and unscrew front of pump andremove debris from debris basket
Posted on Jan 31, 2009
My machine will not complete cycles
timer or control panel fault
if the water wont fill that is one error message
faulty water inlet solenoid
Jul 19, 2016 | Simpson Esprit 750 Top Load 7.5kg
Came up on display f10 and wont work
Hi dear,
F10 error related to OVER FILL. Follow the things below,see how it works.Thanks.
Troubleshooting
Error messages If an error occurs during the program, a message
is shown on the display. To exit the message after
taking action, turn the machine off and then back
on.
The error messages that may be shown in the
display are:
F10 Overfilling
1. Shut off the water tap.
2. See "Drainage error".
F11 Drainage error
Check:
• that no objects are stuck in the drainage hose
outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump. See the "Care and
maintenance instructions" chapter.
• that there are no kinks in the drainage hose
After taking action, run the Drain program or press
the Door Opening button (key symbol) to empty
the machine. If this does not resolve the problem,
call the Customer Care Center.
Jan 27, 2016 | Asko Washing Machines
Washing machine comes up with ERR message
Oct 19, 2017 | Washing Machines
My LG dishwasher is stopping after a few minutes into the wash cycle with an error message OE and making a sound. The dishwasher tablet is still inside the dispenser and while there is water in the unit it...
Hi rebeccasolom,
OE means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
May 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
I keep getting a E 4 signal. A Bosche rep told me the signal is due too much soap in the washer and can be cleaned out with softner. No luck. The cycle starts but stops in the middle with water left...
You can find this issue addressed on another site....
http://www0.epinions.com/review/pr-Bosch_WFMC_3200_Washing_Machine/content_158390980228
Due to popular request, here is more information on the E:04 problem, and some assorted tips:
If you get the E:04 error, he first thing to try is turning the washer off and back on again. You will more than likely have to begin the cycle over, but sometimes this will clear the message.
Since clogging up the drainage pipe, I have gotten that E:04 message when I've used too much laundry soap. I think that's the main reason people see that message. Just turn the washer off and start the cycle again WITHOUT adding any additional soap. I think the suds somehow make the washer think the drainage pipe is clogged.
The other thing that can happen is a genuine clog, like in the case I described in my review. The Bosch is excellently engineered to protect the pump from damage. There is a circular panel on the front of the washer that hides the drainage hose. Remove this panel (simple, but there is a knack to it) and you can pull the drainage hose out. Keep a bucket handy because the hose will be full of water. You may lose a little bit of skin off your hand during this process, and it's best if you can have the salesman demonstrate this procedure for you. That panel is not the easiest thing to remove. You have to reach in past some sharp metal to get to the drainage pipe. Wrap a towel around your hand and BE CAREFUL. It's definitely worth a shot if saving a service call is worth it to you (and clearing out clogs are NOT covered by the basic warranty). My service man assured me that removing this panel would not invalidate the warranty, but you may want to check with your dealer before you open up yours.
It's been about six months and I still adore my washer. I've found the Temp Boost setting is best for cotton towels, Delicates is great for, well, delicates, the Warm Permanent Press setting is great for jeans, and Cold Permanent Press great for most clothes. To avoid getting small items stuck between the glass and the rubber inner seal, do not overload the washer. If I try to wash too many socks, one will now and then end up in that small space. You can cram one big thing in the washer and it will still get clean (I regularly wash a bathroom carpet in there), but DO NOT cram it full of lots of little things. Follow the helpful loading instructions for each cycle.
Nov 04, 2010 | Bosch WFMC 3200 Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Message: drainage blocked
scgawlik,
Happy to assist you,
You said,
The pipe in the back is not clogged, it is wide open. When we removed the cover for the pump in the front and open the valve, the water obviously drains out. However, when you put it back together and try to run it, it will go through a cycle and when it gets near the end of the cycle that when the message appears drainage blocked and won't drain.
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
Sep 14, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
