How do i fit a new drive belt.
  • 15,935 Answers
Loosen the tensioner (if equipped) and re-route the belt around the drive and tub pulleys.
If no tensioner - good old fashioned leverage using a screwdriver. Put it around the small pulley first - then the big.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Aug 19, 2009 | Washing Machines
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Belt will not fit to motor and drum pully
did you loosen the adjusting bolts on the bottom of the motor and slide it in a little
Feb 13, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
