Question about DCS RGS-486GD Gas Kitchen Range
Oven in DCS gas range doew not turn on
The oven in a 36" gas DCS range does not turn on. All the other components including the top 4 burners, the top grill and the broiler function normally. I have been led to believe that the most likely problem is with a faulty oven igniter. The unit is about 9 years old and predates the Fisher-Paykel takeover. In trying to get any information one is directed to deal with a toll-free number that gets you to Brisbane, Australia! Any ideas about the solution and if it is an igniter problem what is the most efficient and economical way of getting a replacement unit to Canada. Thank you jdv
  • 1 more comment
  • Anonymous Nov 29, 2008
    I have the same problem...asume it is the igniter...the broiler is fine....How do you get to the bake igniter ?
    Steve
  • Anonymous Jan 16, 2009
    oven does not turn on
  • Daniel Sosa
    Daniel Sosa Mar 16, 2018
    I have a Dcs rgu366 Oven Not Working" and replaced The Igniter thinking that was the problem But' it ended up having to replaced Dual
    Gas valve not getting the 120Volts @ 1 one End & that fixed my problem the next thing was the Tstat!
    Scholar:
  • 161 Answers
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Posted on Aug 07, 2007
SOURCE:
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
Who is right? And what do I do now?
Funny thing: There's an adjustment right on the gas valves for exactly this purpose.....
Why neither of the groups has been able to figure it out is beyond me!
May 01, 2017 | DCS RGT364GDN 36 In. Stainless Steel...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
One burner out of 6 will not light
It will need to be cleaned under the burner where the gas mixes with air to enable it to burn.
Sep 05, 2017 | DCS Kitchen Ranges
DCS commercial range #36-6-1L running propane. 6 burner tops light fine, but the oven has just stopped lighting after 7 years. When I try to relight the pilot light (depress red button, click cliker) it...
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
Jul 06, 2009 | DCS RGS-305 Professional Gas Kitchen Range
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Jan 02, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
DCS RGS-486GD Gas Kitchen Range Logo
548 people viewed this question
Top DCS Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
