Maytag mah4000aww drum wont spin
I took the back panel off and watched the drum/motor. the rod coming out of the motor spins but wont turn the wheel that is attached to the belt that spins the drum. Is it the motor thats bad?
  • 15,935 Answers
No - it is likely the key for the pulley that has broken.
You'll need to remove the pulley to see if the keyway is damaged. If so - you'll need to change the motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Loud Bearing Noise During Spin Cycle- MAH4000AWW
I don't know these front loaders so well but, here's a couple of things to look for.
1) If belt driven, look for the spring loaded tensioner. Once tension is released, check the pully & see if it has excessive play.
2) Check the gasket on front panel & see if drum has rubbed thru it in order to make metal to metal contact.
3) There is alot of pressure on that rear bearing...make sure it's not egg shaped or scored on the inside.
If all else fails, shotgun it (in other words, replace those moving parts you suspect:)
Nov 15, 2013 | Maytag Washing Machines
Model mah4000aww
Sounds like the main bearing on the back of the drum assembly has gone and needs replacing, the drum has moved out of alignment or the electric motor has burnt out. Best to have a Maytag repair tech or someone who is qualified to look at it.
Nov 05, 2012 | Maytag Washing Machines
Neptune front loader. doorlock light quit working. wont spin.
You will need to change the machine control board and door lock wax motor.
MAH3000AWW PART # 'S 22002988 AND 12002535
MAH4000AWW PART# 'S 22002989 AND 12002535
If yo look at your control board in the control panel you will find R11 burned.
Jun 10, 2011 | Maytag Washing Machines
I had a lot of sheets and a couple of towels in the washing machine and it eventually the load just stopped before the spin cycle(dial on sanitary mode) I drained the water and tried to drain and spin and...
Thank you for using FixYa. Does the drum of your machine appear to move freely when turned by hand? If it does with no resistance, I would say that the drive belt has either come off the motor or it has perhaps been placed under a strain with a "heavy" wet load and and snapped. The drive belt can be accessed through the panel on the rear of the machine. If the belt has simply come off, run the belt round the small pully wheel on the motor and then work it onto the large wheel on the back of rhe drum. Turning the large wheel on the back of the drum in a clockwise direction whilst guiding the belt on will make matters easier.
I hope this as helped. If so please place a Most Helpfull vote
Regards
Duncan
Mar 16, 2011 | LG WM2301HW Front Load Washer
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt(belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH4000AWW
If there are no errors then the motor controller thinks everything is ok.
Do you hear the motor spinning?
the belt in the back may be bad or jumped off.
If you want to look for yourself open the top panel.(3 screws in top rear)
Jan 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
May 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
