Question about Microsoft Windows Vista Ultimate Edition
Excel Recovery Sir, I have been worked in an Excel Worksheet and Saved the file periodically (File Name - Known and the Saved Location is Unknown).  Immediately the System became Hang and I wait for a long time and then Using Windows Task Manager I have closed excel and the file i Have saved was not found. Can you help to recover the file.?
  • 58 Answers
You have to search the file name in all drives.
Posted on Jan 31, 2009
2 Suggested Answers
  • 2386 Answers
SOURCE: Sir,  I have been worked
normally all the MS office files saved in my documents folder, check at this location, otherwise the file will appears in file menu of excel at the top of recent used file. you can also find the file in most recent save document in start menu.
Posted on Feb 02, 2009
Excel 2007 document recovery repeating document on Terminal Server
MS Excel File can get corrupted due to virus attack, missing MS office files, power failure and other possible reason that can be fixed by only use Stellar Phoenix Excel Recovery fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Jan 04, 2015 | Microsoft Excel for PC
Excel 2003 worksheet slow in 2007
Hi Lee, I have recently experienced the same thing. When Excel 2007 or later opens an Excel 97-2003 .xls file, there are major issues of speed. The file is opened in compatibility mode. The best thing to do would be to open the file, then save as (keep the same name if you like) an Excel 2007 .xlsx document (or .xlsm document if there are macros). Close the file, then reopen it, and the compatibility mode issue will be gone. You can now use the newly saved file as a normal Excel 2007 file. Hope this helped.
Mar 25, 2014 | Microsoft Office Professional 2007 Full...
Corrupt excel 2010 file
1 - Using "Open and repair"
Microsoft Excel has a built-in repair tool for corrupted files. To access it, go to File and Open. A menu will pop up in which you'll have to select the file you want to fix and then choose "Open and repair" from the dropdown menu. This will open a dialogue box in which you can pick between the repair option (which will recover as much information as possible) and the extract option (that will copy values and formulas). The two alternatives combined should work fine to save your work.
2 - Saving the file to a different format
If you can open the file but you can't modify it or save the changes, you should use this method. You'll have to save the file to a different format (such as SYLK or HTML) via the "Save as" menu. Once you've done this, you'll have to open the recently saved file and then save it once again (but this time, you'll have to choose the Excel Workbook as the format). By doing this, you'll be creating a fresh new file with all the data from the corrupted file.
3 - Opening the file in Microsoft Word
This option is only available for the people that have the Microsoft Excel converter installed on their PC (it can be downloaded from the Microsoft website). You simply have to open the corrupted Excel file with Word. However, you should know that this method only works for retrieving data (all the structures from the sheet will be gone, such as formulas and macros).
4 - Altering the Calculation option
If your file isn't opening at all you can try to adjust the calculation option. Simply open Excel in a blank workbook, go to the "Tools" menu and look for "Options". There you'll find the "Calculation" tab in which you'll have to look for the "Calculation" section and set it to "Manual". Click OK and then try to open the corrupted file once again.
5 - Linking the corrupted file
In this method, you'll have to link one cell of a blank worksheet to the corrupted workbook. Be sure to create the new worksheet in the same location as the corrupted file. Once you've done this go to the blank worksheet and enter the following in the A1 cell: <Filename>!A1. This will copy the data from the A1 cell of the corrupted file to the new sheet. In case it works, simply click "Edit" on the cell and select an area like the one covers the cell that contain data in the damaged file, and then click Paste. Then (and with the cells still selected) click Copy on the Edit menu.
Jan 23, 2013 | Western Digital Corporation WD ShareSpace...
Excel sheet has been lost how to recover
Lost Excel file can be recovered from:
  1. Recycle Bin - If you have deleted the file with normal delete.
  2. Backup - If have maintained the backup of file.
  3. Email - It may possible that you have mailed the file to someone.
  4. 3rd Party Recovery Software - Recuva, Stellar Data Recovery ...
Oct 29, 2012 | Microsoft Office Excel (License Only)...
What is default name in ms excel? how is possible excel worksheet in excel?
Book1.xls Do you mean that you can't find the worksheet you have establish and you haven't rename the file? The worksheet will be OK if it had been saved.
Feb 15, 2011 | Microsoft Office 2010
Excel file corrupt how to recover
Better Stellar Phoenix Excel Recovery which can fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Aug 20, 2009 | Microsoft Windows XP Home Edition with...
Excel files couldnot opened
It is because your excel file is get corrupted. There are several reasons of excel file corruption; virus attack is main reason of corruption. You can fix this problem with the use of "open and repair" utility of MS excel or you can use Excel repair tool http://www.stellarinfo.com/excel-recovery.htm .
May 05, 2009 | Computers & Internet
Sir,  I have been worked in an Excel Worksheet and Saved the file periodically (File Name - Known and the Saved Location is Unknown).  Immediately the System became Hang and I wait for a long time and then...
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
Forgot password in excel, how to retrieve it
Kodishekar
Not sure if this works on a mac - but it worked for me today on a PC:
download this xla file and then go to tools > addins and add the xla file in, which will all you to unprotect the worksheet you have.
http://www.straxx.com/excel/password.html
Jan 29, 2009 | Microsoft EXCEL 2004 for Mac
Microsoft excel file crrupted
To open a corrupt file; you have to repair the file first.
MS Excel has a special feature to repair corrupt file that is Open & Repair.
Repair a corrupt excel file by following steps:
  • Open a blank wordbook.
  • Go-to the File menu and click on the open button.
  • Now select your corrupt file and click on the arrow next to open button.
  • Select Open & repair option and click on the open button.
  • Save as the file and give the new name.
Additionally you can try 3rd party excel repair software if Open & Repair fails to repair corrupt file.
Sep 13, 2007 | Microsoft Office Standard for PC
Microsoft Windows Vista Ultimate Edition Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
