Question about Acer Aspire 5610-4648 Notebook
My web cam is not wkin in yahoooo
Bank more matkuria dhnbad
  • 4 Answers
Attached the webcam to the pc. open my computer and click add new hardware (meaning install the webcam). open Yahoo messenger and click the webcam icon.If doesnt work still, right click on d general preferences and check if u set your webcam to allow others to see u.
Posted on Jan 31, 2009
I have trailblazer 2008 4.2. p0014 and p1174
0014 = "B" Camshaft Position - Timing Over-Advanced or System Performance Bank 1
1174 =
Citroen/Peugeot:
Cam Sensor Fault
Daewoo:
ETS VALVE STUCK - CLOSED 1
Ford:
Cam Sensor Fault
Hyundai:
Electronic Throttle System #1 Close Malfunction
Jaguar:
System Too Lean - Banks 1 and 2 (Suspect HO2S)
Kia:
Lincoln:
Cam Sensor Fault
Mercury:
Cam Sensor Fault
Oldsmobile:
Cam Sensor Fault
Volkswagen/Audi:
Fuel Trim,Bank 1 Different injection times
Volvo:
Aug 19, 2017 | Cars & Trucks
I have a 2007 ford freestyle and had a diagnostic run and the code p014b came up amd the dealer said tgey have never seen that code. So what does it mean
Scary when the dealer doesn't know.
Code P0014 means there is a problem with the cam timing for either cam B on bank one, or the cam on bank two. It depends on which engine you have.
Bank one is the cylinder head with cylinder one, and bank two is the other head.
You would need to look up the code in a shop manual to know for sure which cam is involved and get the test procedure.
The cam sensor involved is telling the engine computer the cam is not in the place it should be regarding valve timing.
Sep 03, 2015 | Ford Cars & Trucks
P0017 WHICH IS SENSOR B-BANK 1 ?
code p0117 refers to crankshaft/camshaft position bank 1 sensor A--correlation. It also refers to control modules, cooling fan---no signal
I seeing this as a twin cam engine of either 4 or 6 cylinders . . Both sensors on the cams are sensor A so by banks I take it that it is the LH cam (from front of engine) bank 1 and RH cam is bank 2
correlation means that both cams have to read at the same time to indicate a cam has not broken
Apr 26, 2014 | 2002 Volvo S80
2004 745li po368 code camshaft sensor B-Bank 1 but where is it located?
Intake camsensor bank #1 is located at the back of the right valve cover on the left side above the impulse wheel
Exhaust cam sensor bank #1 is located just to the right of the intake cam sensor no the back of the valve cover
Do you now where # 1 cylinder is that bank one (rule of thumb)
Apr 30, 2011 | BMW 7 Series Cars & Trucks
How to set the time belt?
4 Cylinder diesel(4JX1) :
1 - Timing mark
2 - Cam pulley
3 - HP Oil pump pulley
4 - Tensioner pulley
6 Cylinder petrol:
Align crank(C) timing notch mark (1) to oil pump mark.
Align cam pulley(L+R) marks(3) to cylinder head marks
The cam belt has 3 marks, 2 lines and one mark that is actually a row of dots. Align the dots to the crank pulley groove mark(2) and align the other 2 lines to the cam pulley marks. Using a clothes peg to hold the belt to the cam pulleys works wonders to keep it in place while fitting. Please note the arrows on the belt and have them point in the direction of rotation - right to left side of engine
W - water pump pulley
I - Idler pulley
T - Tensioner pulley.
If for some reason you need to realign the cams on each bank :
Standing in front of the car and starting from YOUR left , looking at the cams you should see RE, RI, LI, LE on each of the camshafts.(R for right bank, L for left bank, I for intake and E for exhaust) Right bank camshafts are marked with one dot, left bank with 2 dots on the shaft itself. To align the camshafts to each other each cam shaft gear has a mark on it. Draw an imaginary line between the centre of the camshaft and the centre of the pulley. The alignment mark should be between the two along this imaginary line. The result will be that RI an RE will be at the top of each gear. The same with the left bank.
Nov 08, 2010 | 1998 Isuzu Rodeo
Need device driver for imageview 11-1210
According to Bushnell you can obtain a replacement CD with the software and driver by calling 1-800-423-3537.
Mar 22, 2010 | Bushnell ImageView 111025 Binocular
How can i see web cam of other persson without his permission
Could I have your bank details please without you knowing? What you are asking for is a complete invasion of privacy which is why you cannot do it.
Jul 07, 2009 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
