Question about Teac GF-188 Turntable
Err 4 message?
Err 4 message not listed in owner's manual. Have loaded CD-music disk, but the cd tray is apparently not reading the disk, and I can't use the record function. I suspect that the CD machinery is dirty - is there some way to clean it?
  • prenderl04 Feb 11, 2009
    I did purchase aforementioned laser brushing CD,but it wouldn't play either
  • prenderl04 Feb 16, 2009
    Bought compressed air duster from staples (2 small cans for ~$8.00...problem solved.
  • 104 Answers
Http://cgi.ebay.com/Maxell-Lens-Cleaner-with-Advanced-angle-brush-CD-340_W0QQitemZ110293503861QQihZ001QQcategoryZ48643QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
the above ebay auction is a CD with a little brush built onto it. as the cd spins, it will brush across the laser and dust it off.
Posted on Feb 11, 2009
  • Steve W Feb 11, 2009
    well, about the only other thing you can try without opening the unit
    by a technician, is once in a while unplugging it from the wall for a few
    minutes might reset it. If this does not work then it would have to be
    serviced at a repair shop it sounds. :(
HI when i put disk in cd rom drive the computer only reads for about 3 seconds and then the message says insert a disk..my son has been burning a lot of disks lateluy and not sure why it broke so soon,only...
Loading new device-drivers will not help.
In the first few seconds, the drive is trying to read the first few blocks of data from the media, to see if it is a "data" or "music" or "blank" CD. If nothing can be read (dead laser?) then you get the "insert a disk" message.
> do I need a new unit?
Yes; spend $40 to buy a new CD/DVD reader/writer.
Oct 11, 2010 | HP Computers & Internet
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Jan 01, 2010 | 2000 Chrysler 300M
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
CD ERR 1
Have a 2005 Freelander and the battery died. When I re-charged the battery, the CD changer had a CD ERR 1 message. Could not eject or load a CD and the radio worked. I turned off the radio and pulled off the cover on top of the CD changer. I removed the two screws that hold the frame around the CD changer. I turned the CD back on and the CD went through a test on each CD. I know this solution might not work for everyone, but it worked for me
May 30, 2009 | 2004 Land Rover FreeLander
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
CD will not read or play....ejects ;;ERR message flashes Help
try different KnownGood cd and if still an issue your head unit needs repair internally .(not worth it)
Nov 24, 2008 | 2000 Chevrolet Silverado
2002 Silverado- CD played ERR message
This is not a fuse problem, it may be a dirty laser lens or a broken loading mechanism, buy a CD player cleaner disk, if that won't work you will have to pull the unit out and send it in for repair at an authorized GM electronics repair station.
Nov 24, 2008 | 2002 Chevrolet Silverado
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Disk Stuck In DVD Machine.
Hi, You need to open the machine or at least the top cover and manually extract the CD. Under the cover and on top of the loading tray is a retaining bar held by 2-4 screws. Removing these would allow you to lift the bar and remove the CD easily. In some models/version, there might be an electronic board partially covering the tray assembly. This type of problem happens when the CD is defective, was not loaded properly, or more than 1 is inside. In some cases, it is the loading mechanism that is at fault. Still in some other models/version there is an access/pin hole below the try at the faceplate where you need to insert a straightened metal paper clip to manually push out the tray. Of course the standard precautions apply, power down, remove from the mains. If you are not comfortable on do-it-yourself, maybe you should seek the services of a qualified professional. good luck and kind regards.
Aug 26, 2007 | Sony DAV-SC8 System
Teac GF-188 Turntable Logo
480 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
