Question about Microsoft Windows XP Professional for PC
Hello Sir, I Want to ask you that which partition is Best In NTFS & FAT32
    Sergeant:
    Champion:
  • 289 Answers
The best would be C drive
Posted on Jan 31, 2009
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
May 03, 2014 | Transcend StoreJet Computers & Internet
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
Hello, I bought WD My Book Essential 1 TB but whenever i connect it to my Samsung DVD player it doesn't get recognized. Any help? Thanks
Most probably the format of your hard drive is NTFS. Samsung DVD players only recognize FAT32 formats. If you have the patience and resources try to change the format of your hard drive to FAT32. Better yet since it is a 1TB try to create a partition one NTFS and one FAT32 because FAT32 cannot go beyond 4GB for files.
Hope this helps.
Jul 30, 2010 | Western Digital Passport WDXML800UE...
Which partition is the best in NTFS & FAT32?
For most users running Windows XP, NTFS is the obvious choice. It's more powerful and offers security advantages not found in the other file systems like FAT16, FAT32.
Feb 01, 2009 | Microsoft Windows XP Professional for PC
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
Jan 20, 2009 | Microsoft Windows XP Professional
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Toshiba satellite ps141e 181g1w en 256ram 2ghz celeron wont play commercial dvds
Hello tango13
(01) Which partition(s) is/are FAT32?
(02) Which partition(s) is/are NTFS?
(03) Do you mean your OS partition is FAT32?
A Microsoft Windows OS on FAT32 cannot "see" NTFS partitions. Conversely though, it can see FAT32 and NTFS partitions if the Microsoft OS partition is NTFS.
(04) If your OS is on a FAT32 partition, you need to convert it to NTFS if it is to be able to "see" other NTFS (and FAT32) partitions.
(05) If I didn't understnd you correctly, please, in detail, explain the problem again and tell us what the file system is on each of the partitions you refer to.
(06) What did you install from Toshiba OEM discs?
(07) Do you mean that, after performing one reinstall of WinXP Home that you then used the Toshiba System Restore CDs to restore the system again? (effectively wiping out the 1st reinstall of Windows XP you said you performed)?
(08) What precipitated your reinstalling your OS in the 1st place? (I ask because the reason(s) may be connected to the issues you are currently experiencing.)
(09) Your media player and codec issues are not related to your file system issue(s).
(10) How many **DIFFERENT** commercially-produced DVDs have you attempted to play in your laptop's DVD ROM drive?
(11) The DVD ROM drive spinning and not being able to read your DVDs is either (1) a media compatibility issue or (2) the media is dirty or damaged, or (3) a mechanical issue w/ your DVD ROM drive. In any case, I seriously doubt if it is a software issue. IOW, I believe it is a hardware issue.
(12) Make sure of the following:
(A) The movies you are attempting to play are actually on DVD media and not Blue Ray or some other media type that is incompatible w/ your optical drive (DVD ROM drive).
(B) The media (discs) are clean and not scratched, warped or otherwise damaged.
Please, post back here w/ answers to these questions along w/ any more questions, observations, or comments you might have. Let us know also what else you've tried in attempts to correct the issues you're experiencing.
Thank you
BJ @:)
***IMPORTANT NOTE***
Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved - *then* rate the solutions and choose a "Best Solution". As long as the problem remains open, we will be able to continue to work w/ you on it.
Apr 15, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
