Question about Desa International R40 Utility Heater
I have a 55,000BTU Desa Kerosene Heater Model # R55
When I pug the heater in the motor starts, but the heater will not fire or ignite? Could you give me some advice on what to do?
  • frank_denter Feb 01, 2009
    I checked the coil out on my heater and it seems to be just OK.
    I am going to check out the safety gas valve now. Will let you know how I make out. Thanks
  • 19,396 Answers
You need to check if there is pressure on psi gauge, and if the igniter has spark.
There should also be a screw regulating pressure, check near to the PSI gauge, try also opening it more.
Check that the lines are not obstructed.
The safety gas valve is controlled by a thermocouple, you need also to check that one out.
Posted on Feb 02, 2009
    Genius:
  • 2,920 Answers
Drain the fuel out of it and replace it with all new kerosene....if its set for awhile the kerosene has separated and wont allow it to ignite.
Posted on Feb 01, 2009
    President:
  • 2,559 Answers
Possible reasons for not firing (check each)
1. No fuel in tank
2. Pump pressure incorrect
3. Dirty fuel filter
4. Obstruction in nozzle
5. Water in fuel tank
6. Bad electrical connection between ignitor
and ignition control assembly
7. Defective ignitor
8. Defective ignition control assembly
9. Defective fuel valve (Models equipped with fuel valve only)
Try this
TO START HEATER
1. Follow all ventilation and safety information.
2. Locate heater to provide maximum circulation of the heated
air. Follow all location requirements noted in Safety Information,
page 2.
3. Fill fuel tank with kerosene, #1#2 diesel/fuel oil, JET A or
JP-8 fuel.
4. Attach fuel cap.
5. For thermostat models, turn thermostat knob clockwise to the
high position.
6. Plug heater’s power cord into approved, grounded, three-wire
extension cord. Extension cord must be at least six feet (1.8
meters) long.
Note: Ignitor will preheat for five seconds,
then heater will start.
For thermostat models, adjust thermostat knob to the desired
setting.
Note: A cold heater may affect the thermostat setting.
This thermostat is a general-heating control. It is not intended
for precise temperature control. Adjust thermostat until heater
cycles at the desired setting.
also,for more details and instruction,Here is the manual
  • 163 Answers
HII!!! You Seem to have a problem with your safety gas valve.But first change your ignitor even if it is bad ,There must be enought resistance to open your gas valve.If you put the ignitor new then no flame then you safety gas valve is bad.Good luck..
  • 679 Answers
Need to clean the igniter part by opening it using a screw driver.
let me know for further assistance.
Posted on Jan 31, 2009
  • rockfixya
    rockfixya Jan 31, 2009
    here is a link for your problem>>
    http://reddyparts.com/SP_tips.htm
    hope helpfull.
    Genius:
  • 1,913 Answers
Change your heater coil it has some problem .check it if u can reapir coil then u not need to change .
  • kishor khatri
    kishor khatri Feb 01, 2009
    check your coils resistanse may be your coil resistanse is low.
Reddy Heater R55 55,000 BTU heater spits and sputters but CONTINUES TO RUN. Air pressure is at 3.4 (was 4.0). new lines, Plug is firing well, fuel is old but clean. My question is: is there supposed to be...
If you brought the heater to my shop with the great (no lie!) description of the problem we would immediately grab a flashlight, shine into the tank and look for water droplets rolling on the bottom of the than. (Keep in mind that a layer of water can be on bottom & not show up with the light)
The next thing would be to use soapy water and try to find a crack in or around the plastic cover and move all the way to the nozzle looking for an air leak. 3.4 at the gauge doesn't mean the air is going all the way to the nozzle.
Next, remove the top cover. Does the heater run fine once removed? If so, replace the worn out nozzle. That heater has some age on it and DESA recommended annual replacement.
The filter is more of a strainer than a filter. It is hollow.
Read more troubleshooting tips.
Nov 10, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Feb 15, 2009 | Desa International ReddyHeater® R115DT...
Hello, I have a 55,000 BTU kerosene heater, model # R55 It will not fir or ignite when I plug it in. Just paid $10.00 for a guaranteed online answer and have not received one
Take air preassure from a compressor and turn the fan blades in the back of the motor while you reset the switch. the you know its gumming up and needs to be cleanned and changed parts or a kit added from your local lawnmower supply house.
Jan 31, 2009 | Desa International R40 Utility Heater
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
Desa International R40 Utility Heater Logo
197 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
